Indesit IDC75 condenser dryer not stopping
  • notallbad
    • Oct 2012
    • 1190
    Re: Indesit IDC75 condenser dryer not stopping
    Well decided to disassemble and as suspected the contact between A9 and A12 were welded shut, separated the connection, cleaned contacts and re-assembled. All good now!
    The contact was the very last contact to be accessed so a full disassembly was required.
    No amount of tapping would have freed it in this case but had already tried that, thanks
    Thanks again for the help/advice, very much appreciated.
      • 30977
      not surprised, it really should have had a snubber across the contacts to prevent arcing
      • DeanWy
        WD Sentinel DS5100 (NAS) boot issues
        by DeanWy
        I have a Western Digital Sentinel DS5100 NAS system which has stopped working. It has dual BIOS. I bought the system second hand with an already broken primary BIOS (it rebooted multiple times until second BIOS was used).
        It worked until recently. The system was idle in Windows Server 2012 and a BSOD occurred, I think it was 'critical process died'. Thereafter it didn't boot, it just sat there with no video output and fan speed at 100% (there's a proprietary Windows driver by WD which controls the fan, outside of that it always runs at 100%).
        There...
        07-30-2024, 04:13 AM
      • CapLeaker
        Bosch Nexxt 500 dryer blinking start button - no start fix
        by CapLeaker
        My Bosch NEXXT 500 dryer quit today, press start nothing happens and the start button just keeps blinking. Not cool. Reset the dryer, same thing.
        Even so the buttons feel good, my problem was the start button smd tactile switch on the PCB. Cleaned the switch with alcohol followed with Deoxit and the sucker runs like a champ again.
        I like these easy evening fixes!
        12-07-2023, 04:38 PM
      • notallbad
        Heat pump tumble dryer regas
        by notallbad
        Just wondering if anyone has successfully attempted a re-gas on a heat pump tumble dryer.
        The dryer currently in question runs on R134a.
        The dryer has been completely stripped down/cleaned/tested and re-assembled however there is no heating/cooling effect so working on the assumption it requires re-gassing. Of course, its likely theres a leak which would require soldering or even the possibility that the compressor has an internal fault even though it is running.
        I was thinking of getting a car aircon regas kit or probably easier but slightly dearer an hvac...
        07-16-2023, 01:27 PM
      • Sam Scarbo
        Blomberg DV17600W laundry dryer MCU firmware needed. Please help!
        by Sam Scarbo
        I'm helping my brother to fix his Blomberg laundry dryer. He called a repair guy to have a look and the repair guy said the control board is faulty. They said the replacement board costs $400. Too expensive! 😨 My brother asks me to take a look. He has checked the door switch and thermal fuse, etc., and those seems fine.
        After plugged to mains, there is no display. There is just a clicking sound from the buzzer, like one click per second. No other response.
        I suspect the firmware inside the MCU (ATMEGA64A) got corrupted. Can someone in this forum by any chance provide...
        07-21-2024, 05:24 PM
      • Joe24
        Maytag Whirlpool Kenmore clothes dryer data bus
        by Joe24
        Patient is a Maytag/Whirlpool/Kenmore clothes dryer. Not sure of exact model, doesn't matter. All boards are out of production.
        Specific problem is a Maytag 8544799 / WP8544799 motor-control board, aka Diehl Controls 708879-05. Customer states the board "doesn't work, motor doesn't run". Not sure how the repairman made that assessment, or if it's even accurate. He can't get replacement boards, and the owner decided to buy a new dryer, so whether this board is the problem is speculation on his part. Again, doesn't matter.
        I've been over the board looking for...
        01-13-2025, 06:50 PM
