Dell SE2419HR LCD Monitor
    Hello everyone. Greetings from Malaysia. I'm working on a Dell SE2419HR Power Board and I've identified a few components to be burnt. I can get the other components locally, but not the 65WN2K3 Mosfet. I was wondering if I could replace it with any other common models. If it is in fact possible, can I know what do I need to look for in the spec sheet when replacing the Mosfet.
    Thank you!
    Re: Dell SE2419HR LCD Monitor
    If the MOSFet burned out, then with a probability of 99% the U850 burned out, to replace the mosfet, focus on these characteristics.
      Yes you are right! The U850 is burned out too. I tried googling the component but I'm not really sure what it is. Can you help me out? This is the marking on the component. Also, can I know which marking to look at. A4 right?
        t36R - ld5536
          Error, this is LD5536.
