Thanks to Iotas posting the A3050 service manual in response to my request in my first forum post, I am starting this thread about my RX-A3050.
Using the self diagnostic mode, function C1-7 reports an error with DSP2, IC920.
Is this part still available? Are there recommended suppliers?
I presume I will have to attempt to remove and replace this part.
Further snooping through the service menu...T4-11 cannot read the FW version of DSP2 (makes sense if this part is defective or the datapath to it is corrupted)
A strange observation: many of the front panel buttons seem to be "off by one", shifted-left by one, meaning that if I press Scene4 button, it acts as if Scene3 was pressed. If I press the "AM" button, it acts as if "Tune <<" was pressed. Is that indicative of something else to check?
If I press the appropriate button enough times it responds correctly, but the "default" behavior is one of being shifted to the right by one.
According to the T1 info, this unit has been running for 341 days, 15 hours, 29 minutes prior to this happening.
Thanks all...This looks a bit daunting but exciting. This unit is pretty well packed inside.
