I'm trying to fix this Acer laptop, main board is FH52M LA-J891P
The laptop suddenly turned off during normal use and this is the situation:
-the power supply is working correctly, 19 volts output. But when I connect it to the laptop , no voltage on the charging connector. If I disconnect the charger, no more 19 volts output until I disconnect and reconnect again the the wall plug
-the positive and the negative of the charging connector are not shorted
I have a power supply, a multimeter and maybe a short finder, but still no thermal camera(I'm thinking about purchasing one).
Any suggestion?
Thanks in advance.
Any suggestion?
Thanks in advance.
