Hi, this has panel problem for certain (AUO panel), in the troubleshooting process, after pressing ON button i am with set making a short lamp of backlight with status light shortly white then green/yellow repeated, in this situation main board remain powered and also tcon with all their correct output voltages. I cant find in the service manual description of this state, can you brief me ? thanks
Sony KDL-42W705B panel problem
Re: Sony KDL-42W705B panel problem
Originally posted by Davi.p View PostHi, this has panel problem for certain (AUO panel), in the troubleshooting process, after pressing ON button i am with set making a short lamp of backlight with status light shortly white then green/yellow repeated, in this situation main board remain powered and also tcon with all their correct output voltages. I cant find in the service manual description of this state, can you brief me ? thanksLast edited by lotas; 01-26-2023, 08:20 AM.
Yes i was just watching now YouTube videos saying this, the tv needs an update because i have changed tcon board that was broken also, my question is, after upgrading i will have latest software installed , some years ago i bought two pmic chips to repair original tcon, if i succesfully repair it then mainboard probably will not recognize it as an original component and needs a new update, but since no more new versions available i need to copy tcon eeproms or what? thanks
ps: the panel is not already repaired, needs further efforts
I have flight over the doubts and done the usb update, surprisingly immediately appeared a near perfect image, the first time i have seen one, there are some intermittent black lines , there was a tape masked pin made by me and there is a shorted burnt trace onto the last tab, therefore there is more work to do...Last edited by Davi.p; 01-26-2023, 01:08 PM.
The second question, the burnt traces on the cof tab, the burnt plastic substrate made an air gap between two traces (Signals HC1, HC2, two signal clocks that results shorted together), putting a paper band through it made no difference in the shorted signals, the burnt sign ends in the ACF tape area and i'm convinced that heat modified molecular structure so the glue is now always conductive in that point, how can i bear with this? I thought that pressing or sliding a very sharp cutter i can destroy the trace, is there a better way?
Bad news.. very bad news, after the replacement tcon brokes i have put back original tcon, the previous situation where it requests for an update returned, but now it refuses to load it!!! My premonition was right!!
I ask to experienced users: i have noticed that plugging the power in when keep pressing On button brings to a different state with blue led steady in standby position, leaving button and pressing it again if i remember brings to a pulsating white led but no update beginning, also in subsequent boots, what stands for this function?
Originally posted by Davi.p View PostBad news.. very bad news, after the replacement tcon brokes i have put back original tcon, the previous situation where it requests for an update returned, but now it refuses to load it!!! My premonition was right!!
2. If the update does not pick up, then rename your update file to "upgrade_loader.pkg" (without quotes).
Maybe i am out of slime.. executed renaming ( same folder), put pendrive in tv, done the blue light procedure, waited pendrive led stop after few pulses, removed power, reinserted, white led does 3 - pause - 7 pulses, then turned on with key, tv turned on with backlight an maybe an image, tcon is broken, i see only vertical many colors lines. Thanks Lotas.. again..
