Old 05-18-2015, 09:00 AM   #181
budm
budm's Avatar
City & State: S.F. Bay area
Line Voltage: 120V 60Hz
Default Re: LCD TV and Monitor basic troubleshooting guides
LED backlights bypass using Diode 1N4007.
http://www.badcaps.net/forum/showthread.php?t=46403
Old 05-18-2015, 05:22 PM   #182
keeney123
Lauren
City & State: North Adams MA
My Country: United States
Line Voltage: 120VAC, 60Hz
Good for you this looks like an excellent work around.
keeney123 is offline   Reply With Quote
Old 05-22-2015, 03:20 PM   #183
AcGeorgiegirl
City & State: Issaquah, Wa
Thanks...would be nice if you could include what each video link is "about", though!
AcGeorgiegirl is offline   Reply With Quote
Old 06-09-2015, 11:53 AM   #184
budm
budm's Avatar
Samsung EEPROM reset:Samsung LE37A556P1F Flashing red light
http://www.badcaps.net/forum/showpos...0&postcount=77
"8 pin SMD EEPROM on the bottom of the board, close to where the CI card slot is.
Most of the time it's from Atmel, so it will have ATML followed by a cryptic datecode in the first line.
2nd line should be either (AT)24C256B or "2EB1" (which is Atmel's cryptic way of saying it's a 24C256B)
You need to short out the clock and data pins (pin 5 and 6). Even without the datasheet handy they're easy to identify cause they always have 100ohm SMD resistors connected to them. Otherwise see attached pic.
Solder 2 relatively long wires to those pins and put the board back in place and connect it all up. Plug the powercord in and when it tries to start up (blinking power LED), short those wires for a few secs. Might take a few tries. Unplug the set, remove the short and grab your remote.
Now plug it in again. It should stay in standby.. If not, try turning it off (solid LED).
Then start the TV up in service mode. You do this with the remote. In order, press INFO, MENU, MUTE, POWER. The TV should start up and display the service menu on top of everything else.
Go into the "Option table" menu, make sure "Tuner" is set to AUTO and "Store Demo" is OFF (use the arrow keys and enter, menu button goes back).
Then do a Factory Reset. TV should turn off after a while."
Old 06-22-2015, 11:40 AM   #185
budm
budm's Avatar
Samsung LN46A500T1FXZA: power cycling: bad C102 on main board
http://www.badcaps.net/forum/showthr...LN46A500T1FXZA
Old 06-24-2015, 11:46 AM   #186
DB379
City & State: Prijedor
My Country: Bosnia
Thanks alot @Budm
DB379 is offline   Reply With Quote
Old 06-26-2015, 10:23 PM   #187
budm
budm's Avatar
Samsung BN44-00265A/B
http://www.badcaps.net/forum/showpos...57&postcount=7
Per TOM66:
Consider JP852/JP854 jumper cut - can help solve flickering backlight but maybe also no backlight?
Old 07-06-2015, 12:01 PM   #188
budm
budm's Avatar
http://www.badcaps.net/forum/showthr...ps+blow&page=2
Just FYI for caps blowing even at correct Voltage.
Old 07-06-2015, 04:05 PM   #189
budm
budm's Avatar
Another example of why the new caps on the power supply board go bad:
http://www.badcaps.net/forum/showthr...615#post572615
Old 07-08-2015, 08:57 AM   #190
budm
budm's Avatar
Sony Bravia KDL-32XBR4 324046whc6lv2.2 TCON fix.
Multiple color lines on the screen.
http://www.badcaps.net/forum/showthr...034#post573034
Old 07-13-2015, 09:27 AM   #191
budm
budm's Avatar
LN46A750r1F no backlight due to PWM line stuck low.
Solved by paulstef:
http://www.badcaps.net/forum/showthr...180#post574180
Old 07-14-2015, 01:46 PM   #192
budm
budm's Avatar
Service bulletin for PHILIPS, MAGNAVOX, EMERSON blowing main fuse, thanks to JDC.
Old 07-17-2015, 03:27 PM   #193
budm
budm's Avatar
I do not know why the post comes on twice, ADMIN please delete one of them, thanks.
SONY TV LCD panel/T-CON listing from year 2010.
File Type: pdf SONY Manual_LCD_PANEL_9883805A10_sm_2010.pdf (696.3 KB, 476 views)
Old 07-17-2015, 03:37 PM   #194
Oglon3r
City & State: Minneapolis MN
Outstanding guides!!
Just got an element TV with white coloration. You can see menus and what not.
Will do the testing but after a very basic review of the guys my gut tells me it is possibly the Tcon board.
Thank you for your hard work!
Oglon3r is offline   Reply With Quote
Old 07-17-2015, 03:45 PM   #195
budm
budm's Avatar
You should start a new tread with the make and model, the pictures of what is showing on the screen, the pictures of the whole backside of the TV. It sounds like you have bad GAMMA IC problem on the T-CON that will cause washed out pictures on the screen.
Washed out picture samples of bad GAMMA IC on the T-CON board.
Old 07-17-2015, 04:39 PM   #196
budm
budm's Avatar
The Anode of the LED string is connected to the output of the boosted converter, the Cathode of the last LED string is connected to the Drain of the PWM MOSFET, the SOURCE pin is connected to one end of the current sensing resistor, the other end is then connected to the boosted converter ground return.
The example shows 4 strings, two strings are connected in series to form one long string, so there are two long strings with two LED drivers.
File Type: jpg LED drivers Samsung_BN44-00357A_[SCH].jpg (270.8 KB, 134 views)
File Type: pdf LED drivers Samsung_BN44-00357A_[SCH].pdf (59.4 KB, 402 views)
Old 07-28-2015, 09:03 AM   #197
budm
budm's Avatar
LED backlights troubleshooting video by NORCAL715
https://www.youtube.com/watch?v=hh3z_dkkcUM&app=desktop
Old 07-28-2015, 09:09 AM   #198
budm
budm's Avatar
VIZIO E320-A0 EEPROM replacement video by norcal715.
https://www.youtube.com/watch?v=Sghh8BK5zIw
Old 07-28-2015, 09:12 AM   #199
budm
budm's Avatar
Samsung LN32B360 Voltages and Troubleshooting video by norcal715
https://www.youtube.com/watch?v=ocqnqmBxiqY
Old 07-29-2015, 11:14 PM   #200
budm
budm's Avatar
Sony AZ-1K CTV-61 Training manual
http://www.badcaps.net/forum/showthr...highlight=AZ1K
KDL-xx EX400
Badcaps.net Technical Forums © 2003 - 2023
Copyright ©2000 - 2023, Jelsoft Enterprises Ltd.
