Old 03-11-2016, 02:52 PM   #241
thoma
City & State: Germany
My Country: Germany
Default Re: LCD TV and Monitor basic troubleshooting guides
With pleasure!
regards to all members!!!
thoma!
thoma is offline   Reply With Quote
Old 03-12-2016, 03:49 AM   #242
thoma
My Country: Germany
http://****************/dc_dc/
http://****************/ic_power/
Old 03-15-2016, 06:59 AM   #243
JohnT07
City & State: Wolverhampton
My Country: England
Hi I'm new to the site and hope I'm in the right place to ask a few questions.
My LG tv (42LD490-ZB) wont power up, when it's turned on the power indicator pulses I can only describe as continually going from dim to bright every few seconds, I am considering replacing the power board but is that the best option any advice would be most welcome.
Thanks John.
JohnT07 is offline   Reply With Quote
Old 03-17-2016, 06:31 AM   #244
thoma
My Country: Germany
Samsung ue40F6400ak SMPS Trafo defect
https://www.youtube.com/watch?v=oC1NfvID2-M
5V available Relais klicking no function thats what described in this video
The coils are interrupt from the transformer!
But where can buy this transformer?
regards thoma!
Old 03-30-2016, 08:54 AM   #245
thoma
My Country: Germany
http://tel-spb.ru/remont-tv-lcd/
http://televid-sib.ru/
http://www.arizanotlari.com/
Old 03-31-2016, 10:17 AM   #246
budm
budm's Avatar
City & State: S.F. Bay area
Line Voltage: 120V 60Hz
SAMSUNG service manual, etc.
ftp://helpedia.com/pub/temp/datasheets/monitors/
Info provided by THOMA, thanks!
Old 04-08-2016, 01:52 AM   #247
thoma
My Country: Germany
LG SMPS schematics very fine!
http://televid-sib.ru/index.php?board=165.0
Registration required!!
Old 04-15-2016, 12:17 PM   #248
budm
budm's Avatar
LG LED backlights: LATWT470RELZK
http://www.badcaps.net/forum/showthr...209#post649209
http://www.aliexpress.com/wholesale?...=LATWT470RELZK
Old 04-20-2016, 12:50 PM   #249
budm
budm's Avatar
LED DESIGN FORUM: Avoiding thermal runaway when driving multiple LED strings (MAGAZINE)
Driving LEDs in parallel.
http://www.ledsmagazine.com/articles...-magazine.html
File Type: pdf LED DESIGN FORUM_ Avoiding thermal runaway.pdf (500.7 KB, 243 views)
Old 05-01-2016, 06:33 AM   #250
thoma
My Country: Germany
http://www.sahy.cz/sahy/eshop/5-1-LE...-LED-backlight
spare parts LED
Old 05-02-2016, 01:02 PM   #251
thoma
My Country: Germany
http://advancedreworks.com/blog/refl...al-information
All around BGA Chips!
regards thoma!
Old 05-03-2016, 03:50 PM   #252
budm
budm's Avatar
SAMSUNG backlights LEDs: Not sure if it is any good.
SPBWH1332S1BVC1BIB
http://www.aliexpress.com/item/SAMSU...2-02a437e85ed5
Old 05-13-2016, 03:51 PM   #253
budm
budm's Avatar
Caution when testing LED with protection diode using non-current limiter power supply, you can damage the LED internal Diode.
You can attach Amp meter with power source so you can see what current will flow when wrong polarity is applied to the LED with internal protection diode.
You can easily make constant current source using LM317.
File Type: jpg Caution when testing LED with protection diode.jpg (302.6 KB, 100 views)
File Type: pdf Caution when testing LED with protection diode.pdf (238.7 KB, 283 views)
Old 05-13-2016, 05:26 PM   #254
budm
budm's Avatar
Lg latwt470relzk led
Old 05-13-2016, 09:24 PM   #255
budm
budm's Avatar
How I remove bad LEDs from the strip.
I crush the white plastic body of the LED first then scrape off the rest to expose the two solder pads of the LED, then I use flux and add solder to those two pads using wide tip 60W iron and the two pads just slide off the board.
I had to do 38 of them for the SAMSUNG 40" TV, 12 of the LEDS were shorted and 2 were open. It went pretty fast doing this way, I did try hot air and hair dryer method but takes too long..
Old 05-16-2016, 07:58 PM   #256
Maha
City & State: Managua
My Country: Nicaragua
Thank you very much, excellent post!!!!
Maha is offline   Reply With Quote
Old 05-28-2016, 02:07 PM   #257
thoma
My Country: Germany
http://forum.iwenzo.de/samsung-ue32f...z--t62430.html
http://advancedreworks.com/forum/sho...oting-587.html
http://www.ohmsupplies.co.uk/epages/...roducts/KIT408
http://www.ohmsupplies.co.uk/epages/...roducts/KIT394
Old 05-30-2016, 04:21 AM   #258
thoma
My Country: Germany
http://www.electronica-pt.com/esquem...raining-29695/
Training Samsung F-Serie
http://www.electronica-pt.com/esquem...aa-u8ab-28964/
http://www.electronica-pt.com/esquem...is-u8dc-28959/
http://www.electronica-pt.com/esquem...is-u8dc-28958/
Schematics Samsung H-Serie
Old 05-31-2016, 08:44 AM   #259
thoma
My Country: Germany
http://pcook.ru/related/tz8U3abVxcU
Old 06-06-2016, 10:12 AM   #260
thoma
My Country: Germany
vestal software updating pdf files
http://www.tv.quuq.org/forum/index.php?topic=9562.0
Badcaps.net Technical Forums © 2003 - 2023
Copyright ©2000 - 2023, Jelsoft Enterprises Ltd.
