hey all i have the same monitor as the op and even know the lines are not to bad just yet they come and go, is the only fix for this is to replace the tcon board or is there a different fix?
hi
i probably have the same issue, but the 2nd picture(10:49 PM) is very small - did the screen have like pink vertical lines over the whole screen and replacing the tcon board fix it then?
and do i have to take all of the chips and plates off to get the tcon board plate off to see the numbers on it?
or if the 2nd picture just showed a working monitor, then could it be some ded caps issue and i could just replace them all on the boards? (the 470uf 35v ones)
does it cause the same lines on the screen or something else?
PS: 2208 manual gives some specs for some of the caps, and it only says SD, M 105*C and F 13x21, so does that mean that i can use whatever amps cap as a replacement, because it does not specify any amps and only those numbers and 50V, 470uF etc?
and M means the temp and F the dimensions then?
I don't know. I replaced the electrolytic capacitors in the voltage stabilizer circuits U9, U15, U19. When examining the board, I found a destroyed capacitor C130. Maybe someone will already share the service manual for this monitor?
