First off, what a great community. I've learned a lot so far. Thank you all for your commitment and insights!
I started off with the 5 red-blink error code on my Sony KDL-70R550A (just outside of the warranty timeframe of course). After following the steps in another thread to disconnect cables from the T-CON board to Panel to determine which side was acting up, and then removing those corresponding side tabs, the fix worked!
I had picture again, but now when the TV started up, only the left half of the TV was viewable in normal condition (this also happened to be the side I removed the side tabs from). Most of the right half now showed wide and solid vertical color bars. Menu items or any input source showed up behind these color bars. I went ahead and replaced the T-CON board with the exact replacement item, but the same problem persisted. I cleaned all of the ribbon cables and re-seated them all several times, but that had no effect as well.
My last resort is to purchase a new logic board and see if that makes a difference. Does anyone have any experience or insight with this issue? Is it worth trying a new logic board, or do the above symptoms prove that the panel is bad? Or am I missing something else entirely obvious? Any help is appreciated! Thank you!
