This guy has an RCA 42PA30RQ
    Re: This guy has an RCA 42PA30RQ
    On the X-main test at bottom end of C4022.
      c4022 is a small cap...but here is what i get
        My error. C4032.
          LOL...got it but I get noting and i hear the humming from the x main
            Odd. You have good Vs, Va but no outputs from either board. Is control board LED blinking?
              i only get good Vs/va when I disconnect CN 5000 from the Y-main...when I connect CN 5000 I get multiple clicks from the relay, humming sound to the x-main, and no Vs/Va from PSU
                Y-main is dead then.
                  control board LED is blinking
                    Ok I'll replace the Y board...I checked the Y-buffer per your video and it checked out fine..no shorts
                      One thing to check is if you get good voltages with X-main unplugged from Y-main.
                        what I don't understand is the initial problem with the set was spackling on the screen..I removed the Y-main to check for shorts and found none.when I re installed it, thats when I started getting the problem with the multiple clicking from the relay. So if the LED on the control board is blinking, does that mean the control board is fine?
                          Blinking light indicates control board is running.
                          When you removed the Y-main it's possible you damaged it from ESD...
                            with X-main unplugged from the Y-main...I get zero volts Va... 15 volts on the D15v pin an zero volts Vs
                              here are the readings in order of the pics...
                                The Y-main is most likely bad then.
                                  Ok Tom I'll replace the Y-Main...but will that repair the sparkling problem on the screen?
                                    You can adjust Yrr/Yfr on this set to eliminate that later. I have done it before on the PS42B450. (Same TV, different main board & badge on front.)
                                      Okay...thank you for all your help, I'll order a new or used/tested Y-main from ebay unless you recommend somewhere else?? I'll get back to you with my progress
                                        eBay is fine, usually.
                                          okay thanks..have a good day..and I hope the photos I sent were of good quality for others to see
