I have a 32" Dynex, model number dxl3210a, that seems to be stuck on standby. The red standby light is on however nothing happens when I press the power button to turn on the TV. Opened the back don't see any blown caps and checked the fuses already. Would the power supply board be of suspect?
32" Dynex DXL3210A Won't Power On
Re: 32" Dynex DXL3210A Won't Power On
Are the connectors on the power supply labelled?
Loving the imitation Elna vents on the crappy JH caps...!Last edited by tom66; 07-14-2012, 01:35 PM.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
I count 6 voltage regulators on the main board. Check them all to make sure they are in spec.--- begin sig file ---
--- end sig file ---
Hmm, that gunk seems to be a blob of solder.
Yes the connectors are labeled, photo is below.
I measured a few voltage regulators, I feel some of these seem odd but I'm not sure.
N604
8JH 1117H
pin1-0.58v
pin2-1.84v
pin3-3.32v
N602
8JH 1117H
pin1-2.07v
pin2-3.32v
pin3-5.31v
N611 (Largest one)
AZI0845 ADJEI 829J43
pin1-3.84v
pin2-5.11v
pin3-8.36v
Originally posted by tieny View PostThere are two pins that are labeled 5V1. The higher pin reads 5.32V but the lower pin gives me a reading of 0V.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Originally posted by tieny View PostHmm, It seems when I measure either PON or that 5V1 and press the power button, the TV turns on perfectly. I guess the TV will turn on only when those pins are grounded? PON measures 3.05V and 5V! measures oscilating between 5.14V to 5.16V.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Originally posted by tieny View PostI did remember I saw a small spark when I touched to measure the GND pin between the PON and 5V1 pins. I just resoldered the pin and now the TV is able to turn on perfectly!Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Eh, bad news. I left the TV on for 20 minutes, and it just shut off and I can't get it to turn back on now. While on standby (red LED) PON reads 3.05V, higher 5V1 - 5.30V, lower 5V1 - 5.26V. Would this be a new problem?Last edited by tieny; 07-15-2012, 08:13 AM.
Originally posted by tieny View PostEh, bad news. I left the TV on for 20 minutes, and it just shut off and I can't get it to turn back on now. While on standby (red LED) PON reads 3.05V, higher 5V1 - 5.30V, lower 5V1 - 5.26V. Would this be a new problem?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Originally posted by tieny View PostShould PON and 5V1 read 0V during standby like before? And then voltages would only appear once the power button is press?
So far I just reflowed all the output connectors on the PS board but no luck.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Originally posted by tieny View Postnope, the screen is completely off.
BTW, those JH caps DONT last long at all in smps, they should be changed out.
Kind of wacky having JH and CHANG caps in a PSU with some Rubycons too.. xDMuh-soggy-knee
