Re: Sharp LC-46D62U Static Dots and Lines on Screen
I wonder if the mainboard metal cover is needed, seems to be more of a heat trap then anything.
Freak, got any extra mainboards? Lol, so I see shop jimmy has a ton of mainboards listed for this unit, do I have to match the exact one I have? Mine is triangle 2 WE01, so a revision 1,3 or 4 wouldn't work?
I have a mainboard with that ic pulled. I had another with a cracked screen but it was a 42 inch version. Had that same issue but works after my fix.
I used the 42 inch board I the 46 w no problems.
Yeah, not sure what damage if any I did Reflowing this board. 130+ on a 2006 TV mainboard for a TV that I got for 4.99 that will probably not end up selling for much.
I want to save it as cheap as possible
The 82u has an extra HDMI port and the t-cons look totally different.
do you still have the same picture as you did before after reflowing the mainboard? I'm pretty sure the mainboards fine those suckers getting mighty hot in operation anyway.
hopefully you get it figured out I've done two of those d62u models and one D82 model. all three required reflowing that IC on the main board but I guess it could always be something else as well even though the symptom was identical yours is doing.
when I did my main board I didn't use the oven reflow I used my hot air station and I just heated that s*** outta that chip. took two or three tries but I got it right
The item I was working with was an LC-46D82U. Same problem, fine blue dots across the screen in random patterns. I have just now completed a re-flow process on IC 3502. I used my heart gun and no clean solder paste to heat the IC. I am presently bench testing the item before return to my customer.
Thanks for the informative post.
Thank you for the post and solution. I did try my LC46D82U. I used the heat gun. Now it almost fixes the issue. Sometimes it comes back for no reason...
[QUOTE=jotvguy;596823]The item I was working with was an LC-46D82U. Same problem, fine blue dots across the screen in random patterns. I have just now completed a re-flow process on IC 3502. I used my heart gun and no clean solder paste to heat the IC. I am presently bench testing the item before return to my customer.
How did it turn out on the reflow? Did screen look like this as the issue you were working on?
