Toshiba Canvio 1TB Simple 3.0 - what a P.O.S.
    I bought a Toshiba Canvio 1TB Simple 3.0 as a 3rd external disk for backing-up - others are an Imation M100 and a Samsung S2
    I've always built my computers with two disks - first one for software, second for data
    My backup strategy is copy all files from the data disk to a directory on an external disk, rotating the externals
    I get four backups per each 1TB external disk, then reformat the external and start over
    Recently I needed to do first reformat of the Toshiba
    It was excruciatingly slow on my Intel DP965LT based system, so I swapped to a USB3 port on a SuperMicro C7Q67 setup, in case that was the root cause
    It's just about complete - 48 hours later
    Until now the Toshiba's been satisfactory, but 48-hour reformat time is unacceptable
    I could try the quick format option, but don't have problems with complete format of the other two
    I'm going to try getting a refund on the Toshiba
    Re: Toshiba Canvio 1TB Simple 3.0 - what a P.O.S.
    48 Hour format time? That's crazy. Something's got to be wrong there... Can you check SMART? Wouldn't surprise me if it was full of remapped sectors...
    -David VanHorn
      https://www.badcaps.net/forum/showthread.php?t=42226
      i know what you are going through. 456 days estimated format time.
      the USB board is full of crappy caps dumping noise onto, well, everything. (see link above) so it could well be an issue, but i put my money on a shiteton of interface errors.
      Follow the white rabbit.
        Good point...
        -David VanHorn
          After 48+ hours, outcome in 1st pic
          Seems it's not supported - refer 2nd pic
          Truly a P.O.S. !
            Truly a P.O.S. !
            again, USB board.
            here is the smartctl output of the canvio that i had to deal with.
            === START OF INFORMATION SECTION ===
            Device Model: TOSHIBA DT01ABA300
            Serial Number: <removed>
            LU WWN Device Id: 5 000039 ff4c49a16
            Firmware Version: MZ6OABB0
            User Capacity: 3,000,592,982,016 bytes [3.00 TB]
            Sector Sizes: 512 bytes logical, 4096 bytes physical
            Rotation Rate: 5940 rpm
            Form Factor: 3.5 inches
            Device is: Not in smartctl database [for details use: -P showall]
            ATA Version is: ATA8-ACS T13/1699-D revision 4
            SATA Version is: SATA 3.0, 6.0 Gb/s (current: 3.0 Gb/s)
            Local Time is: Mon Jan 19 11:19:13 2015 MST
            SMART support is: Available - device has SMART capability.
            SMART support is: Enabled
            === START OF READ SMART DATA SECTION ===
            SMART overall-health self-assessment test result: PASSED
            Error 74 occurred at disk power-on lifetime: 521 hours (21 days + 17 hours)
            When the command that caused the error occurred, the device was active or idle.
            After command completion occurred, registers were:
            ER ST SC SN CL CH DH
            84 51 01 c7 f5 62 00 Error: ICRC, ABRT 1 sectors at LBA = 0x0062f5c7 = 6485447
            Commands leading to the command that caused the error were:
            CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
            25 03 08 c0 f5 62 40 00 00:00:00.877 READ DMA EXT
            25 03 08 c0 f5 62 40 00 00:00:00.875 READ DMA EXT
            25 03 08 c0 f5 62 40 00 00:00:00.874 READ DMA EXT
            25 03 08 c0 f5 62 40 00 00:00:00.872 READ DMA EXT
            25 03 08 c0 f5 62 40 00 00:00:00.870 READ DMA EXT
            Error 73 occurred at disk power-on lifetime: 521 hours (21 days + 17 hours)
            25 03 08 c0 f5 62 40 00 00:00:00.869 READ DMA EXT
            Error 72 occurred at disk power-on lifetime: 521 hours (21 days + 17 hours)
            25 03 08 c0 f5 62 40 00 00:00:00.867 READ DMA EXT
            Error 71 occurred at disk power-on lifetime: 521 hours (21 days + 17 hours)
            25 03 08 c0 f5 62 40 00 00:00:00.865 READ DMA EXT
            Error 70 occurred at disk power-on lifetime: 521 hours (21 days + 17 hours)
            25 03 08 c0 f5 62 40 00 00:00:00.855 READ DMA EXT
            SMART Self-test log structure revision number 1
            Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
            # 1 Extended offline Completed without error 00% 707 -
              Worse than downloading Ubuntu on 56K in 2005, LOL.
              ASRock B550 PG Velocita
              Ryzen 9 "Vermeer" 5900X
              16 GB AData XPG Spectrix D41
              eVGA Supernova G3 750W
              Alienware AW3423DWF OLED
                Originally posted by RJARRRPCGP View Post
                Like downloading ISOs on 56K, LOL.
                right! i remember doing that. Debian SPARC for my Sun Ultra 60.
                  No more updates from me after this
                  Returned to Officeworks who swapped it for a new WD My Passport Ultra
                  Didn't even charge me the difference in prices
                  The pleasure of dealing with a top-tier bricks-and-mortar retailer
