Did you use time-delayed type fuse for the main fuse?
Does the main fuse blow if the secondary of the transformer is not connected to the rectifier?
The TOROID transformer has very high inrush current when power is first applied to the transformer winding.
Yea I only had T3a glass fuse which I pulled out of another sub and it blew that. Its the fuse at the back of the sub.
The fuse in the AC cord is ok.
Erm ive not tested with the transformer disconnected yet. Which colours are the secondary (All of them connecting to the main board). Theres yellow, grey, blue and red going into the main board.
So there are two orange wires on the transformer then?
What is that big black blob on the top left with black cable tie on it? https://www.badcaps.net/forum/attach...2&d=1448240886
You can probably get other transformer to replace it.
Do you have any scraped linear power supply?
To earth would I just make a connection from the ground/earth pin on the terminal to say the bolt next to it making contact with the chassis?
Earth pin of the AC Inlet to the chassis.
So now you need to get new transformer.
The two wires on the transformer are the primary winding of the power transformer.
