Just picked this set up hoping that it would be the side tab fix that I;ve seen on other 70" TVs. Not the case this time. Part of me is excited about this, part of me is a little disappointed. The set powers on but there is no backlight and no picture. I see 384 volts across the big cap. 12V to the main board is present, as is 24V. There is a pin on the PSU at CN201 labeled, "T-CON_ON". It measures 0V as do the two pins at CN201 labeled 12V T CON and the pins labeled 12V at CN202 which connects to the T-Con. I haven't tried to see if there is a picture with a flashlight but the lack of power to the t-con leads me to believe there isn't.
At this point, I've unplugged the t-con from the main and also tried the t-con connected with the four ribbons to the screen disconnected.
No dice.
No dice.
