So... This was an interesting one.
Bought this TV for a few quid from a member on here who gave up on it. Essentially, poor picture quality, looked like a Z-sustain fault. Originally had problem with colour distortion due to damaged Z-sus ERC inductors. Previous owner replaced Z-sustain but failed to install all screws, this appears to have caused the new board to fail taking the SUS IGBTs out with it.
So, originally, removed all IGBTs and tested using o'scope for gate drive waveforms: definitely good on low side, hard to tell on high side...decided to give it a shot anyway.
Replaced six IGBTs in SUS path and powered up with bulb in place of fuse on board. Bulb glowed dim then full bright, and same fault presented itself: dead short Z-sus. Found one lower IGBT in sus path to be shorted and both gate drive resistors measure 50kohm or so, should be around 10 ohm each. Luckily, the bulb seemed to have saved the other five IGBTs which all tested good. Replaced that IGBT and the resistors. Powered it up again...same IGBT went bad! Realised I had left some screw out on the board...d'oh!! Replaced that screw and the IGBT a third time...success! Set gave a decent image with bulb in series (some maldischarge); taking bulb out gave a perfect picture.
Lessons learned: check all screws are installed, and use a bulb tester, saved me twice from replacing a whole load of IGBTs!
Biggest TV so far. Decently made! Ultimately this only occurred because all the screws weren't installed. On these boards it is absolutely vital to install all screws or failure WILL occur!
