My son was watching his TV when it just went blank. The TV is only 2 years old. I know almost absolutely nothing about TV repair/troubleshooting. I can't see throwing away this TV and buying a new one when it probably only has about $4.00 worth of bad components that need to be replaced.
Since I'm getting nothing at all I "assume" there's something bad on the power supply. I went ahead and removed the PS and checked out the tops of all the electrolytic capacitors on the board and they're all good and flat. No bulging at all on any of them. I found a YouTube video and learned that the little black barrel components on the board are not supposed to have continuity and I got continuity on the three components with the red circles. Not sure what those are. The one in the Blue circle is a fuse I think and it has 3 leads and I got continuity between all three leads so I think the fuse is good. I plugged it in and tested the voltage at the power connector hot lead in the purple circle and it read 88.7 volts (I tested it with it still installed in the set with all the connectors on and the main board connected to it). Not sure if that's right or not.
Anyone got any advise what to do next?
