TV Sharp AQUOS LC-60LE635E TV not power ON
    Hi. Am new in this forum
    A have Sharp AQUOS model: LC-60LE635E
    And my tv not start on.
    today i replaced the power board with a working one. The problem still remains.
    if you could help me i would be very grateful
    i think it's a flaw on the main board
    here's my video
    https://youtu.be/juAvTriU-ms
    Best regards.
    Re: TV Sharp AQUOS LC-60LE635E TV not power ON
    no one knows? how could he help me?
      Look at this...
        and this.....
          Thanks for the service manual but I already knew that ...
          According to this book, it is a power board failure,
          but I switched the power panel to another that worked on the previous TV 100%
          Anyone have any idea ??
          Not in the forum repairers etc?
          Thanks.
            Update my blink error light
            A have 2 long and 5 short blink.
            Look video
            https://youtu.be/WgiJ3UZ_D2g
              disconnect one of the flat cables between the T-con board and the lcd panel, Does the tv turn on and give half screen? If not, reconnect the cable and disconnect the other cable and try again. If the tv stays on you have a panel problem.
              No the book says "Panel Power supply error" In this case the Panel likely has a short killing the panel supply voltage FROM the power supply
                here's a try on your theory a little earlier.
                first disconnected one flat cable.
                error equals black screen light flashing. 2 slow 5x short
                then i plugged the flat cable back in and unplugged the next, same error black screen light flashes....
                so the led panel is ok?
                  What Voltage measurement have you done on the connectors of the power supply board?
                  Upload the pictures of the boards using attachment for us to look at.
                    ok.
                    i measured the voltages on the pins.
                    so if I disconnect the panel from the main panel and measure it on the table.
                    i get on pin 15 / 5V
                    when i make contact with pin 15 and pin 14 (BU5V to PS-ON)
                    i get on pin 5,6,7,8 12.95V almost pure 13V
                    i don't get 12V on pin 1.2.
                    if i plug the power board back into the tv and plug in the main board, i get 12v on pin 1.2 but hold the current until the light starts blinking then i have no more voltage on pin 1.2
                    but some more
                    on the LED light connector
                    1,2,3,4 ice here I get no tension not when I have a board on the table or when it is mounted on a tv
                      You need to report the Voltage readings (ALL CABLES IN PLACE) for each pin (except GND) of the PD connector when TV is off and when power switch is activated:
                      TV OFF:
                      Pin 1, 2 PNL12V = xxx V
                      Pin 5, 6, 7, 8 UR13V = xxx V
                      Power switch activated:
                      TV OFF:
                        Ok Budm.
                        when i plug the tv into electricity the light starts to go on immediately.
                        after a few seconds the light blinks.
                        the measurement results are
                        PIN 1, 2 PNL12V = 0V
                        PIN 5, 6, 7, 8 UR13V = 12.95V
                        that's it
                          So you are saying you have 0 volts on pin 16 as well? Then there is your problem.
                            pin 16? I didn't measure it or ??
                            since Mr Budim told me to only measure pin 1 2 and 5 6 7 8
                              Pin 16 is..PNL_POW, this stands for PaNeL POWer, and is the line that turns the PNL12V (PD-1,2) on and off. I suspect it should be about the same voltage as the PS-ON (3.3~5v)
                              If you have the voltgae on PD, pin 16 I suspect you could have a bad Q7120 regulator ic, This is a 12 volt regulator ic with on/off I have seen this before
                                budm was just showing you an example of how you should report your testing.... he said to measure / test ALL pins on the PD connector.
                                  now i will measure all the pins once
                                  but I tried the Q7120 warmed up with a hairdryer just like one tried on youtube and it didn't connect the tension
                                    ok now i measured the voltage a little more carefully.
                                    when i turn on the tv in 220v
                                    the first 5 seconds I have a voltage on the following pins like this
                                    PIN 1, 2 PNL12V = 12V
                                    PIN 3 = 0V GND
                                    PIN 4 = 0V GND
                                    PIN 5 =12,89V
                                    PIN 6 =12,89V
                                    PIN 7 =12,89V
                                    PIN 8 =12,89V
                                    PIN 9 =0V GND
                                    PIN 10 =0V GND
                                    PIN 11 =0V GND
                                    PIN 12 =0V GND
                                    PIN 13 AC-DET = 3,33V
                                    PIN 14 PS-ON = 2,86V
                                    PIN 15 BU5V = 5,05V
                                    PIN 16 PNL-POW = 3.30V
                                    PIN 17 = 0V
                                    PIN 18 = 0,40V
                                    PIN 19 DIMMER = 0V
                                    PIN 20 = 0,45V
                                    PIN 21 OFL = 0V
                                    PIN 22 ERROR = 0V
                                    PIN 23 = 0V
                                    PIN 24 STB = 0V
                                    here are the results of measuring the first 5 seconds when I plug the cable into the electricity. (Main board conectet whit power board)!
                                    after 5 seconds i have voltage only on PIN 15 / BU5V = 5V
                                    that's it
                                      Based on what you are saying, I suspect you have a fault with the main board, because you have the standby (BU5V) but you do not have the PS-ON to turn ON the power supply. If there is a large BGA ic on the main board I suspect that could be the problem, try heating the ic and see if it stays on longer
                                        i tried going with the hair dryer main chip on the main board but the thing is identical
                                        here's a video of what it looks like when the voltage drops
                                        https://youtu.be/huzyFnhFcis
