Ok guys, got this tv as none working, got it home plugged it in and it fired up with no problem, used it for a week and then image disappeared, still boots up ok and stays on with back lights but no image, I'm getting correct volts from PSU to main board and back once turned on, next thing I check is fuse on tcon and that is fine, then checked the volt readings on the output side of the tcon. Got some strange very low volts, so got another tcon put that in and still getting low readings, think I may have a main board prob
Baird 55 inch uhd no display
Re: Baird 55 inch uhd no display
Maybe unhook the tcon ribbons from panel, see if you have same readings. (best policy is to do all connecting and reconnecting of such with tv UNPLUGGED)Last edited by nomoresonys; 04-30-2020, 07:28 AM.
readings from the tcon, all seem to be the same with or without ribbons, now checking buffer boards for shorts, tryed removing one ribbon at a time, but still no pic on any half of the screen, seems strange that i picked it up in this condition, pluged in when getting home and it worked,
It is a serial flash memory IC
https://cdn.badcaps-static.com/pdfs/...ba94e02774.pdfWilling to help but I'm no expert.
just read though that, and not sure if i understand, thanks btw,
so on VCC i get 3.3v, HOLD 103 i get 3.3v, CLK i get 0v, 100 get 0v,
CS i get 3.3v, 101 i get 0v, 102 i get 3.3v, this is when tv is turned on, is this correct ?
or is this where the fault is, can't find any shorts on buffers or faulty caps
You really need to use an oscilloscope to check the IC. A meter is virtually useless for this task other than checking VCC and Ground. The clock frequency would be too high for a meter to give any meaningful readings up to 104Mhz.Willing to help but I'm no expert.
