Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting TVs and Video Sources
Thread Tools Display Modes
Old 05-02-2022, 04:37 PM   #1
brassicGamer
City & State: Sussex
My Country: United Kingdom
I'm a: Knowledge Seeker
Default LG 50PA4500 Plasma Troubleshooting
Hi folks. This panel seems to be a 'favourite' on these forums. I've checked through all the existing posts and my issue doesn't match up with the common faults described. I think it might be the logic board.
I acquired it second-hand recently and the previous owner described the panel working fine until a power cut, when it only turned back on briefly. The apparent issue was that, when powered on, the TV would display the manufacturer logo and then go into standby mode. I figured this was the main board shutting it down after a test condition failed.
I checked the capacitors and found that all the 100uF, 100V caps had blown their arses out. Replace them and tried again - same problem. No other visual problems are apparent. (Note: the user was a heavy smoker and I have had to clean the boards and chassis from top to bottom - the same problem existed before and after I cleaned everything.)
I did the usual steps of measuring voltages (all good) and unplugging boards in sequence and none of this made a difference. I then desoldered and checked cap C802 because of the sheer amount of reports that this goes bad, but it was absolutely fine.
Something changed around this point. Now when I plug it in, I don't get the LG logo anymore, just some momentary snow before there is no image (and no sound - there never has been), but the panel is 'on', instead of going into standby like before. The Y-SUS board is making some noise when powered, but not when the unit is off or in standby. Also, the red light on the main board is lit.
I have tried the AUTO_EXT_GEN test pattern feature and no picture is produced, though it does alter the sound coming from the Y-SUS board. There is a green light on the logic board, which is displaying what looks like an error code (one long dash, one short dash, repeated once) but I have no documentation to refer to (the service manual appears not to include such codes).
Any ideas?
p.s. I've noticed a common factor people discuss with this panel is clicking relays - mine appears to be a revision that has no relays.
brassicGamer is offline   Reply With Quote
Old 05-02-2022, 05:03 PM   #2
Biruslapio
City & State: ST
My Country: Brasil
Line Voltage: 220V 60Hz
I'm a: Student Tech
Default Re: LG 50PA4500 Plasma Troubleshooting
That Y-SUS is totally blackened by heating, check it and Z-SUS for cold soldering joints.
Disconnect the main board from the PSU, then the TV will auto-start when you plug in AC cable, that way it's easier to rule out the other boards.
For the auto-gen you need to disconnect the LVDS cable, if the panel lights up and display black without pixels fading or misfiring everywhere both sustain boards are ok.
Biruslapio is online now   Reply With Quote
Old 05-12-2022, 05:13 AM   #3
brassicGamer
I removed the heatsink nearest the driver board and tested all the MOSFETs and Schottkeys. One of the MOSFETS is bad. I guess I should also test all the others just to make sure.
Old 05-18-2022, 10:26 AM   #4
brassicGamer
I found another one and they're actually IGBTs. First time working on a plasma panel so I've not come across these before. Ordered some as I don't have any in stock. They were in series with failed capacitors so I guess they got slammed by unfiltered current over a long period of time until they failed. I'm hoping that replacing these fixes the problem.
Old 05-18-2022, 10:44 AM   #5
Biruslapio
City & State: ST
My Country: Brasil
I'm a: Student Tech
All plasma sustain boards use IGBTs, and they're the worst part about the repair, hard to find original parts, so if you run into a RJP63F3 or 30J127 compare it against an original, if the label has nothing in common or is misplaced it's probably fake and may or may not blow up.
Old 05-18-2022, 03:58 PM   #6
brassicGamer
Quote:
I found some 30J121s on Mouser, which are same spec but rated for 600V instead of 300V, so hopefully they will do the job.
Old 05-18-2022, 04:50 PM   #7
lotas
City & State: Sochi
My Country: russia
Quote:
And how are you going to install such a transistor if it has a different case (TO-3P) and it is not insulated (metal)?
File Type: jpg GT30J121-30J121-TO-3P-IGBT-TRANSISTOR-30A-600V.jpg (184.7 KB, 10 views)
lotas is online now   Reply With Quote
Old 05-20-2022, 04:09 AM   #8
brassicGamer
Quote:
Seems like a good place to ask such a question!
Old 05-20-2022, 04:33 AM   #9
vinceroger69
City & State: Nuneaton Warwickshire
My Country: uk
I'm a: Hobbyist Tech
not sure if these will work https://www.ebay.co.uk/itm/194364884...sAAOSwyLhhQa3F
vinceroger69 is offline   Reply With Quote
Old 05-20-2022, 07:33 AM   #10
Biruslapio
City & State: ST
My Country: Brasil
I'm a: Student Tech
It won't, the heatsink and hole spacing are different, replace IGBT with the same model, be caureful of fake parts.
Old 05-24-2022, 03:36 PM   #11
brassicGamer
Okay, okay. I got lucky and someone was throwing away a Panasonic Viera panel literally as I was driving past them. It had two RJP30Ks in it, which look like a good match:
Model___Voltage_Amps_Pulsed_Package
30F126__330V___30A__200A__TO-220
RJP30K__360V___40A__300A__TO-220
Old 05-24-2022, 04:33 PM   #12
Biruslapio
City & State: ST
My Country: Brasil
I'm a: Student Tech
Ok. Are you replacing 30F126 with RJP30K? What happens is that the transistor's pins in Panasonic boards have less length, they may not reach the holes all the way, solder them well.
Old 05-25-2022, 03:19 AM   #13
brassicGamer
Smile Re: LG 50PA4500 Plasma Troubleshooting
It's cool, they're literally the same length. Lucky, I know, but thanks for the heads-up.
Old 05-25-2022, 06:25 AM   #14
brassicGamer
Well, it made no zero difference to the symptoms (some snow when it first powers on, then nothing), so the problem must be further back. On the verge of giving up on this but I've put a lot of effort in so far cleaning it up (from the smoking tar). Would be nice if I should just swap in working boards to find out which one is the problem.
Old 05-25-2022, 06:52 AM   #15
Biruslapio
City & State: ST
My Country: Brasil
I'm a: Student Tech
When IGBTs fail often their gate resistors and some 2W resistors go open from the current surge.
I thought the boards were blackened from the heat, it's actually smoke, that must smell.
Old 05-25-2022, 07:09 AM   #16
Biruslapio
City & State: ST
My Country: Brasil
I'm a: Student Tech
Ok, I'll go into more detail, check these circled components.
On the Y-SUS these 5 pin optocouplers drive the IGBTs, they cannot be shorted, also there are some 2.2, 10 and 100 OHMs SMD resistors next to them that fail, the IGBTs and MOSFETs gate resistors are circled too.
On the top picture the "fusible" resistors are marked and cannot be open.
These procedures are valid for the Z-SUS.
This model has buffer boards failure quite frequently, it's important to test them. During power-up you can measure VSCAN, -VY and ZBIAS to see if they are stable and matching the panel sticker.
Old 06-01-2022, 09:12 AM   #17
brassicGamer
Thanks for your time on this, I really appreciate it. I thought I would list the component labels identified in case it further helps others dealing with a similar issue. I found only found two failed components.
Optocouplers (as arranged: left to right, top to bottom):
IC402, IC481, IC401, IC501, IC552, IC553, IC441, IC442
Resistors (27 Ohm):
R420, R417, R485, R482, R413, R415, R416, R414, R449, R448, R453, R452.
Resistors (15 Ohm):
R490, R489, R572.
Resistors (330 Ohm):
R576.
Resistors (2.2k):
R577.
Resistors (39k):
R571.
IC501 is closed, but all the resistors are reading their expected values except for one of the 2.2Ohm through-hole ones (R283). Time to salvage replacements!
Old 06-02-2022, 09:15 PM   #18
Biruslapio
City & State: ST
My Country: Brasil
I'm a: Student Tech
I circled what I could see in the image, not all those components are suspicious or fail regularly, the opto model should be 155E and the most suspicious resistors are 1.0, 2.2, 10.0 and 100 OHMs next to the opto.
I have a Y-SUS repair log from 2018 and it went similar to your story, I should've looked at it first.
log:
D402 D2217 SF20A300H not shorted but leaking
Q404 30F126 shorted
Q401 Q402 30J127 shorted
IC501 155E optocoupler driver shorted
C501 shorted, linked to VCC and cathode of IC501
2R2 next to IC501 open
In that TV there was some damage on Z-SUS, look at R221 and components next to it.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2022
Powered by vBulletin ®
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
