Old 05-12-2022, 09:06 AM   #1
Fripacks
City & State: QC
My Country: Canada
Default Plasma Panasonic TC-P42C2
Hi guys,
Hi, I have Panasonic model TC-P42C2 with Blinking led on the front, I found this TNPA5066AC SN Board defect, now the TV working with the new board but picture is very weak with blue color predominant and some horizontal lines, I check all the flat wires connections on the board and they ok, could you tell me if it's the new Board can cause this or the plasma panel is defect?
Fripacks is offline   Reply With Quote
Old 05-12-2022, 12:26 PM   #2
kasfamily
kasfamily's Avatar
City & State: Vologda
My Country: Russia
Line Voltage: 230VAC 50Hz
Default Re: Plasma Panasonic
Show a photo of the image on the screen
kasfamily is offline   Reply With Quote
Old 05-12-2022, 03:58 PM   #3
Biruslapio
City & State: ST
My Country: Brasil
Line Voltage: 220V 60Hz
I'm a: Student Tech
Wrong variant of the board? If your original board was for example TNPA5066AB and you replaced with AC the voltages are tuned differently and will change how the plasma panel operates, causing these picture issues.
Biruslapio is offline   Reply With Quote
Old 05-13-2022, 06:41 AM   #4
Fripacks
City & State: QC
My Country: Canada
Default Re: Plasma Panasonic TC-P42C2
The original board is TNPA5066AD, the new board is TNPA5066AC, do I have some adjustements to make?
Old 05-13-2022, 07:42 AM   #5
Biruslapio
City & State: ST
My Country: Brasil
I'm a: Student Tech
Yes, that will require magnifying lens, hot air and patience, you have to compare the two boards side by side and check every component, some of them are different.
Or you can look at this .pdf, it contains only the SN schematic, and search "*", all components marked with * varies between suffix revisions (AC, AD etc), then look at said component in both boards and add, remove or swap them.
If you cannot or do not want to do that, then using an AD variant is the only option.
