Hi All,
My Sony bravia xbr55x810c got stuck bootlooping. Tried to install firmware with a usb. It starts the update but at ~5 min when the progress is ~20% it restarts again. I dont know about much technical stuff. All I did was open the main board and heat it up with a blow dryer hoping something would change.
But it seems to be a very common problem where main board replacement is required? But I can't afford to throw money on a new board atm so I found someone throwing away their Sony bravia xbr55x850c because of broken screen/panel. I was wondering if I can the 850c board?
I am aware the boards are different. 810c uses T-217-001-0 whereas 850c uses A-2082-564-C and the shapes are a little different but the underlying connectors seem to be the same
https://encompass.com/item/11048226/Sony/T-2017-001-0/
https://sony.encompass.com/item/1038.../A-2072-564-C/
Sorry if this is a weird question. I'm a real noob but willing to put in the time and effort. I can get a multimeter and measure any voltages if needed. But I would need guidance on what to measure. The only experience I have is with breadboards and not PCBs but I'll do my best
