HP 15 LA-C701P not turning on
    hello friend i ma new here , First, thanks for all your helpful posts .
    I have HP 15 LA-C701P motherbord not turn on , no 3.3valw no 5valw .
    5/3 ldo are ok
    entrep 1 and 2 = 0v
    ec_on = 0v
    With diode mode maltimetter show 12 with beep (it normal??) on pl8 (5valw coil) .
    Re: HP 15 LA-C701P not turning on
    Sound like a short to GND. What's the reading in Ohms Mode, low range (200 or sinilar)?
    FairRepair on YouTube
      Did you measured resistance immediately after power plugged in?? If yes, you may get weird value. Allow caps to discharge for some time and then measure again.
        Thanks for the answer , there is no short to GND i already inject 5 v .
        Please , I want to know how to judge the resistance (what is the normal value and at what point we can say it a short ).
          Never inject more than 1 volt ! it's a critical you can distroy other component
          start by first step :
          Voltage at D/G/S of PQ 202 and PQ 203
          What's the consumption with/without ram
          RTC section :
          voltage of JCMOS1 = PCH_RTCRST# and JME1 = PCH_SRTCRST#
            Thanks for the answer .
            YES i measured resistance immediately after power plugged in and the value keep changing .
            tank you for help
              You cannot measure resistance or diode mode if there is power to the logic board !!! Confirm this.
              If you have power to the board, remove it and allow some time to discharge the capacitors, then check the resistance without any power. 30 seconds or more is enough to discharge the caps.
                [QUOTE=lapfix;1185748]Never inject more than 1 volt ! it's a critical you can distroy other component
                yes first i inject 1.2 v When I did not find a voltage drop i inject 5 v
                Voltage at D/G/S of PQ 202 and PQ 203 are ok 19v / 25v /19 and ACOK is 3v so i tink that charging section is ok .
                I dont have power supply to measure consumption with/without ram i am useing old motherboard and take 1.2 v from cpu supply it working with me .
                but I will buying one soon .If so, I would like to know how to use consumption in troubleshooting laptop .
                  thank you for your help
                    RTC section :
                      You dont answer the questions properly and completely. You dont have a dc supply also. It'll be difficult to proceed further.
                      Check the basic requirement of SIO and answer these queries:
                      01.Is dc jack light glowing?
                      02.Battery charges??
                      03.Check whether 3V and 5V is generated on coils just after adapter insertion. Voltage should be available on coils for a few seconds only as Deep Sleep Well is involved here.
