This laptop has a too long history already. I bought it working but with the hinges broken. When I was trying to fix it, pulled the motherboard out and when I was assembling it again, like many people, I plugged the speaker cable in the wrong connector (white one near the ram slots) and killed the CPU.
I then replaced the CPU i7-4500U with a i7-4510U. Cleaned ME and it was working again fine, or so I thought until I installed windows and saw that it was not completely true.
The issue is, when I shut it down, it shuts down normally and if it has the battery or the power adapter or both are attached, it powers itself on again after around 3s. The power button it working fine.
It only stays off if no battery is connected and I pull the power cord right after it shuts down. Then I can plug the power back and it stays off.
The only thing I can think of is some power signal is telling it to turn on again. Could it be that the i7-4500u and i7-4510u have some different power signal pins?
I have another board with the same reference (DABLIDMB8E0 REV:E) but with a 5th generation i5-5200U and around the CPU there are 2 or 3 resistors set in a different configuration
In bios configuration I don't see any enabled option that could cause this behavior.
Edit: Can it be NPCE985LA0DX IC issue?
Thank you.
Thank you.
