I received this 43' TV. It has no standby voltage and the owner had it on when it banged and shut off.
With a quick look I found one resistor burnt on top side
R9101 0.24Ω
and at the back smd resistor R9142 22Ω
Both were reading with MM in MΩ
The schematic is attached to this post.
I investigated nearby components and found N-Mosfet Q9101 is K8A65D1 instead of STF24NM65N as per schematic. The resistance between drain and source is 4.4Ω. Should I consider it shorted and the culprit of the failure or is this normal?
The photos uploaded are after resoldering new resistors
R9101 0.24Ω
