HP Probook 450 G1 charging white LED Continuously flashing
    HP Probook 450 G1 charging white LED Continuously flashing after plgging the charger. I've programmed with fresh bios but still same problem. No 15v in run power section. Some days ago I got a probook 4540s with same problem. I couldn't fix that. Anyone here to help me?
    The schematic is attached with a picture of 15v of page no 36.
    The board model is
    Rampage_MB
    12241-1
    48.4YW05.011
    Re: HP Probook 450 G1 charging white LED Continuously flashing
    try Another keyboard and report.
      without keyboard it's also showing same thing.
        The board model is
        Rampage_MB
        12241-1
        48.4YW05.011
        Same problem here. If I can fix it, I will comment it here.
        Good luck, in the meantime!
          i have the same problem
          did you fixit or not?
            same problem here
              Can someone explain where or how this 15V is generated? Looks to be related to SPWON.
                That looks like a typing error, it should be 5V_S0 .Look at page 2 of the schematic. SWITCHES , inputs 5V_S5 Outputs 5V_S0
                  That is good to know, that some schematics have typing errors. A while ago, I had one HP schematic with also 15v. Yes, it did measure 5 volts and with no voltage divider I couldn't figure where it came from.
                  Thank you for the learning experience.
                    put 10 kom resistor betwin 18 and 8 pin of RT8223
                    bcose U2605 -temp chip has to have such resistor but dont have and RT can not go main 3.3 and 5 v
                      I tried 10k resistor but did not work. In my case it works some times itself
                        same problem me too.i have 2 motherboard with same problem.some news?
                          First try with original charger.Second,have you removed rtc battery?and please
                          you would better start a new thread.
                            I have the same problem. some news?
                              Diagram page 99, starting sequence indicate what voltages it has.
                                HP Probook 450 G1 charging white LED Continuously flashing after plgging the charger. I've programmed with fresh bios but still same problem. I couldn't fix that. Anyone here to help me?
                                The board model is
                                Rampage_MB
                                12241-1
                                48.4YW03.011
                                  Its most probably RTC failure. Probe the RTC Circuit. Usually its a resistor or cap gone bad in RTC circuit.
