2 LG TV's in same room, one remote turns both on or off ...
    I have 2 LG TV's in a room. It seems the power button is the only IR button on the remote, since pressing the power button on either remote turns on/off both TV's. Once turned on, the remotes only work on their respective TV's (that is a setting I set on each, I gave each it's own ID)
    I have "solved" the issue by putting electrical tape over most of the sensor on front of the TV's so they dont pick up the other remote's signal, but I was wondering of there was a more elegant electrical fix that could be done on the board of the remote and/or TV to make the remotes power button truly independant
    Re: 2 LG TV's in same room, one remote turns both on or off ...
    hahah this is really funny project.. open each RC and put black plastic ring ( should cover the end of LED ) on the IR LED so it will be focused at straight direction LOL
      I accomplished basically the same thing by taping over the reciever. I was wondering if there was a way to replace a component in the remote and/or TV to make it distinct
