bios for HP EliteBook x360 1030 G2
    Re: HP Elitebook x360 1030 G2
    Originally posted by Fuzer View Post
    I there
    I have a problem with the motherboard of this notebook.
    When i connect the power supply the power supply LED blinks 7 times, i was researching for this problem and found that this is a BIOS related problem.
    Then i flashed the Bios with a CH341 programmer and soldering tho the motherboard and still the same problem.
    Does anyone had similar problem or possible solution?
    note: I flashed the 128Mb bios, could the problem be on the other bios chip?
    Compliments
    post both original bios here..BIOS Requests ONLY!
      I there
      First of all thanks for your reply.
      In attachment there's the dump removed from the 128Mb bios chip.
      Do you want the dump from the other chip?
      I must solder the wires then to motherboard to make the dump, but you can check if this dump is ok?
      Compliments
        I there
        Compliments
        try..
          Re: UNLOCK BIOS PASSWORD HP EliteBook x360 1030 G2
          anyone can help me on how to reset bios password for my X360 g2
          and if you need bios file , how to read that from laptop ?
            Re: hp elitebook x360 1030 G2 BIOS!!
            Can anyone help me pinpointing the location of the bios chip?
            Purchased a new chip and brought for repair, but the guys can not find the location of the chip.
            Hope you can help!
            Regards,
            John
              Hope you can help!
              Regards,
              John
              See the picture at post #8
                Thanks!
                  Originally posted by ace.code View Post
                  DUDE U R A LIFE SAVER
                  IT WORKS FINE
                  I JUST WANT TO ASK IS THEIR A SOFTWARE I CAN BUY FOR DELETING PASS FROM DUMP????
                  Please how to use this .bin file ? What combination of keyboard to use ?
                    Re: HP EliteBook x360 1030 G2...help
                    I need help removing password from this file please.
                    W25Q128JVPQ
                    Thanks.
                    Stay healthy!
                    Best regards,
                    evildeluxe
                      HP X360 1030 G2 - Password removal
                      Bios has password, normally I'm ok removing them, but this one is being stubbon.
                      Any help would greatly appreciated.
                      Thanks in advance.
                        Re: HP X360 1030 G2 - Password removal
                        Originally posted by mechanicalbytes View Post
                        bios has password, normally i'm ok removing them, but this one is being stubbon.
                        thanks in advance.
                        try and post result if job is done
                          yesterday I installed a new motherboard to my pc.
                          install the drivers. up here ok
                          Once I went to the hp program, I sure tried to configure the secure boot but it did not accept the administrator password, so I gave it to cancel and closed the program.
                          my surprise was when today I went to open the pc and it got stuck in the hp logo.
                          Do you know how I can solve it?
                            Originally posted by RethoricalCheese View Post
                            Logic error? Can't read again if it is overwritten with another dump.
                            First try to get a correct dump, then start trying other files.
                            I did not do any dump, I just installed the pc drivers and when I tried to put the safe start, the hp sure program gave me an error. I canceled it and restarted and now it stays in the logo without any reaction.
                              Originally posted by 2taou.fik.58 View Post
                              Hello, I've recently purchased a second-hand laptop.
                              The previous owner did not tell me that the laptop has a BIOS password.
                              After some research, I've successfully dumped the laptop's BIOS .bin file (16 MB).
                              Here it is, could you please try and see if you can do anything to remove the password?
                              Thank you very much.
                              With what program have you been able to get the password.
                              When I try to erase the data from the chip it does not allow me to rewrite the data either.
                                HP EliteBook x360 1030 G2...code
                                hsn-i04c hp motherboard
                                  Re: HP EliteBook x360 1030 G2...code
                                  read post # 10
                                    So guys, I have an HP Elitebook x360 1030 G2. How can I remove the bios password? Can someone send me a pm if he can help me?
                                      post the bios backup
                                        I hope this one is good :-) I used Universal BIOS backup.
                                        No sorry.. Not the good file. How do I backup the bios?
                                          try..
