Need help with HP-Pavilion 15-n266sa
    Hi laptop starts ,fan spins but no display ,caps lock blinking
    If someone have bios dump but I already reprogram bios from hp website still the same
    Its machine with Amd a8 cpu will attach schematic and if someone can help thx
    Re: Need help with HP-Pavilion 15-n266sa
    How many caps lock blinks? First find on HP website, what does that mean.
      Its continuous blink caps lock
        Reflow it
          post your old bios dump
            got no better things to do so i extracted and decrypted both bios files for this model
            Im Back... sort of...
              Need KBC bios file I deleted by mistake
                Sladjo Laptop start but show only backlight so its like starting but blank,bios is ok because i use on another same laptop and its working ,Also try another screen and connector cable
                  Hi, is this the same schema in the first post?
                    No I dont have for this one
                      Can you find a 5 pins chip around the screen connector?
                        yes
                          And what is the number on that chip when you find it?
                            Some days ago I found same problem with a HP Probook 440 G0. That was the problem with LAN Controller Chip. I suggest you to have a try with taking out LAN chip.
                            Good Luck!!!
