HP Probook 450 G0 bios dump please
    Re: HP Probook 450 G0 bios dump please
    sorry it looks like you used it ..
      try..
        thankyou Peste ,yes that one was successful one time
        then i reflashed the same one , what i dont know is why the problem is persisting
        erase > flash
        i am using Bios Chip Programmer CH341A which has a chip grabber on it
        maybe the bioschip is faulty on motherboard?
        thanks
          try bios from post # 22
            thankyou Peste i flashed another bios and is now booting and i installed latest bios from hp site . i had to put hardrive with with windows 10 on it already
            because the it wont detect any usb drive or dvd drive at all
            the usb ports are not working at all and the wifi not working and dvd drive not showing
            all drivers are installed its very odd
            i have enabled all options in bios to be ON i am now wonderign why the usb ports dont work they do not look damaged at all , 2 ports are 3.0 and 2 are 2.0 none of them work in windows or outside windows
            any ideas, thanks
                fiji MB 12238-1 48 4yz31.011 dump bios if you please.
                  hp 450 g0 fiji MB 12238-1 48.4yz31.011 dump bios please.
                  I have 2 backups made with asprog and ch341a. None of them do anything after I put them on. Which give the error is when the LED flashes ii bag near the power supply, so.
                    nobody?
                      nobody?
                      try..
                        Originally posted by peste View Post
                        try..
                        Thanks Over, resurrected. The problem solved as always.
                            can somebody post HP PROBOOK 450 G0 FiJi MB-12238-1 (48.4YZ33.011) bios dump please.
                            It would be very helpful for me.
                            Thanks.
                              Thanks.
                              Upload your Original BIOS here, write your Device Serial Number and someone will try to help you.
                              all donations are welcome,
                                try this ok tested
                                  Attached is a dump of the BIOS from an HP 450 G0. Unfortunately it is password protected, so it would be much appreciated if someone could kindly return a copy with the password removed. Thanks!
                                    read..https://www.badcaps.net/forum/troubl...before-posting
                                      Thanks for the pointer, Peste - I was able to download RCUnlocker and clear the password myself. I much prefer to be self-sufficient!
