Hi laptop doesn't recognize battery but says fully charged ,and wont work from battery ,dont have schematic
Asus N550JV wont work from battery
Re: Asus N550JV wont work from battery
First make sure you use a good battery.
If it's a motherboard issue, use the boardview to help you. Check battery MOSFET and current sense resistor (and fuse if there is one).OpenBoardView — https://github.com/OpenBoardView/OpenBoardView
You need to go back more.
Dcin and bat+
Am not looking at shem but somewhere here it tells if adp not present then use battery you need to look here.
check b+ line.
check battery pin if giving out 19v,check if that pin is shorted if so then inject 1v and start your amps less then 1 then increase as you go
what rev is your board
check
PU8000
pin14 is gnd and rest is not so se if other pins beep with gndAttached FilesLast edited by Stevie2001; 06-17-2018, 06:08 AM.
It's important to know if the problem regard battery charge voltage or smart battery signal, so check on BAT_CON
PIN 1_2 -> charge voltage
PIN 3 -> SMB0_DAT_CLK_CON -> 3.3 v ?
PIN 4 -> SMB0_DAT_BAT_CON -> 3.3 v ?
If no voltage on pin 1_2 = charger IC or a signal to it or a mosfet
It was working with AC adpater so AC_BAT_SYS wasn't shorted.OpenBoardView — https://github.com/OpenBoardView/OpenBoardView
