hi trying fix cousins tv with no backlight tv is hitachi 50hyt62u i beleve the power suply is vistel 17ips20. i checked power coming out the boared to leds and was getting meter jumping from around 2v to 9v so i disconected leds from bored and was still getting the same. i tryed testing the leds wen unpluged from bored but wasnt able to get any reading. im wondering if the power detects that the led's have failed it wont put the rite power out or if it is a fault with power bored is it posable to test the leds with multimeter the way i tryed by disconecting from power supply and testing from the conector rather than strip screen. thanx for any help
Backlight 50HYT62U
Re: Backlight 50HYT62U
yes iv checked seen i have picture, i tested power been sent to leds its low gose from 2v to 9v jumping back nd forth it dont get high as id xpect to power the leds. but i wasnt sure if sent low power 1st then if leds were ok give the rite voltage. i tryed test the leds with multimeeter but got no reading i would of though when unpluged from power suply and tested i would of had some reading and was thincking it may be leds. thanx fr reply
Originally posted by TheBugger70 View Postthe wires are just short of a inch away from the bored its just the way looks on pic. thanx will have look at that now and see what can work out
i checked for voltage while tv was on with led pluged in and with out led pluged in i got the same jumping from 2 to 9v im not sure what you mean high low, im trying to work scmatic u sent out gona go prod about with meeter just trying to understand scmatic lol. thanx fr help
Originally posted by TheBugger70 View Posti checked for voltage while tv was on with led pluged in and with out led pluged in i got the same jumping from 2 to 9v im not sure what you mean high low, im trying to work scmatic u sent out gona go prod about with meeter just trying to understand scmatic lol. thanx fr help
Connect your meter between ground and pin1 of cn501 (The RED wire) then plug in and turn on the tv. This voltage should jump to 80v or higher and if there is a fault it will drop to 24v
The picture in post #8 shows you checking pin7 (black wire) which is the led return.Last edited by R_J; 05-30-2022, 04:00 PM.
A small point but the output lead from the power supply feeding the leds you will find that the red wire on Vestel TV's are -ve and the black wire is +ve!
I don't know why Vestel did this but that's probably why you are also getting low voltage. Bizzare but true!
So connect the black meter wire to chassis and the red wire of the meter to the black wire coming out from the PSU. Making sure you have set meter to dc voltage!
If you don't get a voltage of around 120V plus then connect red and black leads to the output connector from the psu.Last edited by cheeky2; 06-05-2022, 08:50 AM.
