Dear Members,
I would like some of you to share your experience with Vcore shorts to determine whether or not this card is salvageable.
We have a 750ti here with a vcore short, it does not have an external atx power connected on this model so i can only assume that it is a 75w max from the pcie slot only.
On the 12v rail there is a dead short, almost 0 ohms, i voltage injected it to confirm and yes whatever voltage you put into it is what is being directly fed to the GPU.
Do you think that this GPU could still be operational if i repair the power circuit. I could replace all mosfets and driver uP1641P It should be fine again, however im not sure if the PSU short protection would have been enough to protect the GPU chip from a blast of 12v power?
What do you think would be the smartest course of action??
