Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Power Supplies and Power Supply Design
Thread Tools Display Modes
Old 03-02-2021, 09:59 PM   #1
Kg74
City & State: Edina, mn
My Country: Usa
I'm a: Knowledge Seeker
Default An old dinosaur bench top power supply - help needed
I have had this old bench power supply which I have decided to look into repairing. I have no idea where it came from.
Attached is a picture. I cannot find much information on it to even figure out what it is rated for. The analog display goes to 25V, but the voltage regulator chip is rated for 5V (UA7805 - KC - F 8221 - Korea). The cap is rated a 100uf 50V. There is noting on the bottom but some traces. Pretty much what is seen is what is there.
Any insights into testing? Capability?
Kg74 is offline   Reply With Quote
Old 03-02-2021, 10:09 PM   #2
R_J
City & State: ☻
My Country: Canada
I'm a: Professional Tech
Default Re: An old dinosaur bench top power supply - help needed
The control is used to vary the ground of the 7805 so the output voltage will vary from +5v to something higher 12~20v
There looks like a burnt resistor above the switch? or is it just a black shadow?
Something like this: The component values are different but it shows the general idea of how it works.
R_J is offline   Reply With Quote
Old 03-02-2021, 10:19 PM   #3
Kg74
My Country: Usa
Thanks RJ - sounds like it may be worth some attention. I measured the transformer output and it is 25V a/c. Diodes seem to check out.
Any suggestions on testing the UA7805? Can it be done on board or should I remove it?
Old 03-02-2021, 10:25 PM   #4
redwire
City & State: Alberta
My Country: Canada
It was a trick to make a fixed voltage regulator IC adjustable by putting a pot in series with its GND pin. So you could get 5-30V depending on the transformer voltage. It has a 50V filter cap, IC is 35V in max. Similar schematic below.
For the size of this, it needs much better heatsinking something I would add to the back panel. It won't make 1A for long without heating up too much.
If the IC has failed, I would convert it to use a LM317 on a heatsink at the back.
Why is the resistor burned on the brown wire?
redwire is offline   Reply With Quote
Old 03-02-2021, 10:35 PM   #5
R_J
City & State: ☻
My Country: Canada
Just measure the voltages, the regulator should have around +35v input and the output should vary depending on the position of the control, (you can also check the ground pin voltage on the ic) The output of the regulator should ajust from +5v to around +30v If it does not, the regulator ic is likely bad.
The burnt resistor looks like it is the current limiter for the led?
Old 03-02-2021, 11:01 PM   #6
Kg74
My Country: Usa
Thanks redwire and thanks again RJ.
RJ - The regulator reads about 30V on one leg and nothing on the other, regardless of where the pot is set. So the 7805 is dead.
The browned resistor is for an LED and is working.
I will look into the LM317 conversion - Redwire I assume you are talking a regulator with three legs vs this current through the board 2 leg setup. Any recommendation of wire gauge? I figure I could pull the 7805 and solder jumper wires in the existing holes and run it to the back per your suggestion.
Old 03-02-2021, 11:05 PM   #7
R_J
City & State: ☻
My Country: Canada
Do you measure any voltage on the output? If you get 0 volts the regulator must be open internally
Old 03-02-2021, 11:09 PM   #8
Kg74
My Country: Usa
RJ- No voltage on the output.
I put the ground of my VOM on the heatsink and poked the probe under the board. One leg read 30V and the other gave no reading.
Old 03-02-2021, 11:15 PM   #9
R_J
City & State: ☻
My Country: Canada
It could be that the ground circuit is open, check the resistance between the large capacitor negative and the regulator common(can/heatsink) then vary the control and see what resistance you measure. The pot might be open?
Old 03-02-2021, 11:19 PM   #10
Kg74
My Country: Usa
Would I be able to use this eBay board? https://www.ebay.com/itm/LM317-Step-...4AAOSw-itXrY-G
Take out the existing board, mount the eBay board to align with the existing pot control, cut a hole for the LED Voltage display, remove onboard LED power light and run jumper wires to the panel and keep the analog scale and wire it somehow?
Turn the dinosaur into something modern, but keep the old school look and gain some function.
Old 03-02-2021, 11:28 PM   #11
Kg74
My Country: Usa
RJ - I performed the test. VOM negative to heatsink and VOM positive to negative leg of the gray vertical 100uf 50v cap. As I turned the pot the resistance would increase and decrease.
I did the same for the really big 25000MFD cap and the resistance would vary, but not in a linear fashion.
Old 03-02-2021, 11:28 PM   #12
R_J
City & State: ☻
My Country: Canada
Yes, that would work, I would remove the old analog meter and install the led readout in the hole.
Old 03-02-2021, 11:33 PM   #13
Kg74
My Country: Usa
RJ - Thanks again. I will place the order. It will be weeks before it shows up.
Any idea how to get the analog meter to also work?
Old 03-02-2021, 11:35 PM   #14
R_J
City & State: ☻
My Country: Canada
The analog meter is just connected across the output, so as long as it is still connected there it will still work. So there is no problem using both.
Old 03-02-2021, 11:40 PM   #15
Kg74
My Country: Usa
Excellent. Thanks again for your help RJ. I will circle back in a few weeks when the board comes. Appreciate your and redwire's answers and guidance.
Old 03-03-2021, 05:18 AM   #16
stj
stj's Avatar
City & State: Europe
My Country: some shithole run by Israeli agents
that's actually a 3a or 5a regulator,
7805K
but heatsinking it to the case will be tricky because you need an insulator-kit AND a plastic cover to stop the case of the regulator touching anything on the table and linking to the chassis - instant 5v!
stj is offline   Reply With Quote
Old 03-03-2021, 12:58 PM   #17
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
My Country: USA
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist Tech
7805's are no more than 2A or so whether it's TO-220 or TO-3, just determines how much heat it can dump. Swapping and rewiring for a LM317 is a good idea but keep in mind that you will still heat thermal limits fast with lower voltage outputs.
This looks like a homemade versus a mass produced PSU? Not sure.
oh boy that ebay ad pisses me off, do not say "step down" and especially not "buck" with linear regulators...aaah... (though marking a SMPS with "LM317" as search bait is equally annoying.)
eccerr0r is offline   Reply With Quote
Old 03-03-2021, 02:36 PM   #18
stj
stj's Avatar
https://www.cricklewoodelectronics.com/78P05.html
i actually have 3a and 5a 7805's in one of my old parts drawers.
dont ask how big the heatsinks were on them back in the mid 80's!!
Old 03-03-2021, 03:15 PM   #19
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
My Country: USA
Nonstandard 7805...
Just like LM317T vs LM317K, the "K" version is no more current - they want you to buy LM350's and LM338's ...
Old 03-03-2021, 03:34 PM   #20
sam_sam_sam
City & State: Sunny Jacksonville FL
My Country: USA
Line Voltage: 120 Volts 60 HZ
Quote:
Originally Posted by eccerr0r View Post
Nonstandard 7805...
Your are right but I think that they can dissipate the heat better than the regular lm317 or the lm7805 could at least that what I found
__________________
9 PC LCD Monitor
6 LCD Flat Screen TV
1 Dell Mother Board
15 Computer Power Supply
All of these had CAPs POOF
sam_sam_sam is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2021
Powered by vBulletin ®
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
