Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Power Supplies and Power Supply Design
Thread Tools Display Modes
Old 10-29-2020, 08:00 PM   #61
beetle1303
City & State: Singapore
My Country: Singapore
Line Voltage: 230VAC 60Hz
I'm a: Knowledge Seeker
Default Re: Tefal GV8962 Pro Express steam iron - no power
Quote:
Originally Posted by CapLeaker View Post
I think C7 may be shorted too. Take it out and remeasure it out of circuit.
OK, I think it will mostly likely be a destructive removal..
beetle1303 is offline   Reply With Quote
Old 10-29-2020, 08:02 PM   #62
beetle1303
Quote:
Originally Posted by budm View Post
Now check the resistance between GND and VCC pins of the IC's.
Hmm.. I missed out the most devastating part when remove U2 without the right tools - the black material cracked into pieces when I tried hard to remove it with a soldering iron and a tweezer...
So, ya, can't do any test on U2
Old 10-29-2020, 09:57 PM   #63
budm
budm's Avatar
City & State: S.F. Bay area
My Country: USA
Line Voltage: 120V 60Hz
I am talking about the two IC's that you found the spec sheet to get the VVC pins, check the resistance of those VCC pins.
BTW, since you cannot do SMD repair so it is a moot point to keep trying to fix the board.
__________________
budm is offline   Reply With Quote
Old 10-30-2020, 02:39 AM   #64
beetle1303
I took out C7 - off circuit fluctuated between 3.8 - 14 uF, probably the contact points are somewhat damaged... The resistance between the 2 C7 pads reads 20.8 ohm, same reading with the C7 in circuit.
Old 10-30-2020, 02:45 AM   #65
beetle1303
The resistance of those 2 ICs are both 20.8 ohm. After removed C7, same reading.
Yes, indeed it will be purely academic from now on. And if there is any further fault finding worthwhile, it can only be done with SMD removal, and not restoring as I am not equipped and not capable.
At this juncture, I want to thank you both, BUDM and CapLeaker, for spending time coaching me. It's been a pleasure learning under your coaching.
Thank you very much.
Old 10-30-2020, 01:32 PM   #66
budm
budm's Avatar
My Country: USA
So pin1 of U2 is the Output pin for feeding VCC for the IC's.
You can try removing C7 first to see if the resistance will go up or not, there are also other filter caps connected to this VCC line that have to be checked, worst case will be that the IC's are damaged.
Old 10-31-2020, 09:40 AM   #67
beetle1303
I have already removed C7 and the resistance remains unchanged at 20.8Vdc. I have also attempted to trace and measure all the caps an resistors leading to the Vcc of the 2 ICs. Not surprisingly, I do not know what I was doing... But I feel the resistance pretty much measured 20.8Vdc in most places along the trace.
I reckon that this would not go very far to determining what else is faulty beside the now apparent U2 being blown opened. But suffice to say replacing the R1 with a 5W 100 ohm was a MAJOR MISTAKE!! Nonetheless, it has been very educational, and I want to thank you (and CapLeaker) once again for patiently guiding me alone this learning journey.
Thank you.
Old 10-31-2020, 01:48 PM   #68
budm
budm's Avatar
My Country: USA
Thank you.
At least you gin the knowledge. One of the weak point of Buck converter is that when the pass device (I.E. MOSFET) shorted out, the input Voltage will be dumped into the load and can cause lots of damaged, they should at least put crowbar and a fuse on the output.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2021
Powered by vBulletin ®
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
