Old 11-23-2020, 04:20 PM   #1
ajshoe
ajshoe
City & State: cincinnati, ohio 45215
My Country: usa
Line Voltage: 120VAC 60HZ
I'm a: Hobbyist Tech
Default samsung washer control board - DC92-01021H
Have a Samsung washer - top load that only starts when it wants to. Normally pushing the start button after selecting the cycle - it won't start, just beeps. constantly adjusting cycle and hitting start may get it to work. I took out the control board (wax or gum coated) - don't see anything obviously wrong. Put in another used control board - washer works perfectly (start button works).
Is there a way to remove this wax / gum off the board ( DC92-01021H) ? I'll post pics tomorrow morning.
Most likely bad caps ? I read on another post - bad voltage regulator. thanks
ajshoe is offline   Reply With Quote
Old 11-23-2020, 04:30 PM   #2
CapLeaker
Leaking Member
CapLeaker's Avatar
City & State: Atlantic Canada
My Country: Canada
Line Voltage: Ground, 0Hz
Default Re: samsung washer control board
heat that epoxy up with hot air then pick it off.
Old 11-23-2020, 05:23 PM   #3
ajshoe
ajshoe
My Country: usa
Did back side. Not easy job.irs not epoxy - very soft. Gummy. It is clean thou. Work on top side tomorrow
Old 11-23-2020, 05:46 PM   #4
petehall347
City & State: worcester
My Country: United Kingdom
cycle selector might need cleaning
Old 11-23-2020, 05:52 PM   #5
ajshoe
ajshoe
My Country: usa
appears that all functions work -rotating the knob selects any cycle. the only fault is the start button doesn't start the cycle that was selected. The start button is acknowledge as I hear a beep when pressed. I can get the washer to start but is totally randomly. can't figure out sequence to get it to run consistently.
Old 11-23-2020, 06:00 PM   #6
petehall347
lid switch ok ?
Old 11-23-2020, 06:07 PM   #7
ajshoe
ajshoe
My Country: usa
think you missed the earlier post - I put in a used control board from ebay and washer works perfectly
Old 11-23-2020, 06:11 PM   #8
petehall347
yes i missed that bit .
Old 11-24-2020, 10:17 AM   #9
ajshoe
ajshoe
My Country: usa
pics - found bad cap 10Uf 500V. replaced it - washer seems to work now. ran 3 loads with no issues.
Old 11-24-2020, 02:14 PM   #10
budm
budm's Avatar
City & State: S.F. Bay area
Line Voltage: 120V 60Hz
Good job! where is the cap located? This will help lots of people. The conformal coating is always a pain to remove, yous is more likely to be silicone based conformal coating. Washer model number?
Old 11-24-2020, 05:29 PM   #11
ajshoe
ajshoe
My Country: usa
Default Re: samsung washer control board - DC92-01021H
in the pic - it is the cap with the black x on top of it - top of the board (actually easy to remove and install new one). thought I put model # in topic - my mistake. Samsung washer model #WA50F9A8DSW/A2. Is there an easy way to remove that silicon coating ? I spent a lot of time peeling it off.
Old 11-24-2020, 06:08 PM   #12
CapLeaker
Leaking Member
CapLeaker's Avatar
My Country: Canada
aah! Top left, first pic! Nice job!
Badcaps.net Technical Forums 2003 - 2021
