Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting TVs and Video Sources
Thread Tools Display Modes
Old 08-26-2021, 09:12 AM   #1
ioanban
City & State: Worthing
My Country: uk
I'm a: Knowledge Seeker
Default samsung UE49MU6120KXXU image problem
Hi guys,
I have a samsung UE49MU6120KXXU with a flickering problem and some lines on the screen.
I have looked around the forum but i didn't manage to find a solution to my problem.
I've already tried to clean the cable strips but nothing changed.
I've atached some pictures with all the boards and a video with the problem for you to get a better idea.
https://youtube.com/shorts/QNxt4RIdJ0g?feature=share
Regards,
ioanban is offline   Reply With Quote
Old 08-26-2021, 09:22 AM   #2
ioanban
My Country: uk
Default Re: samsung UE49MU6120KXXU image problem
https://www.youtube.com/watch?v=AOnFCJCTACk
Old 08-26-2021, 11:42 AM   #3
Davi.p
Davi.p's Avatar
City & State: Milan
My Country: Italy
I'm a: Hobbyist Tech
defective panel, try disconnecting one flat cable to the screen at a time and watch results..
Davi.p is offline   Reply With Quote
Old 08-26-2021, 02:24 PM   #4
ioanban
My Country: uk
Quote:
I have removed the flat cables one at the time but I'm not getting any image , all screen goes black .
Old 08-26-2021, 02:48 PM   #5
Davi.p
Davi.p's Avatar
City & State: Milan
My Country: Italy
in this case i have no answer for now, must take pictures of the panel's boards searching for silkscreens of signals, if you find some clk-something, must cut them one by one, one side at a time..
Old 08-27-2021, 02:20 AM   #6
ioanban
My Country: uk
Davi, i have uploaded pictures with all the boards in the first post .
Old 08-27-2021, 03:40 AM   #7
Davi.p
Davi.p's Avatar
City & State: Milan
My Country: Italy
panel's boards are under a metal frame under speakers...
Old 08-27-2021, 12:01 PM   #8
ioanban
My Country: uk
I have already tried to fiddle with the strips from the panels but i haven't noticed any changes on the screen .
You have some pictures with the panel boards, i have don them in sections so that you can see them better, attached here .
Old 08-27-2021, 04:36 PM   #9
Davi.p
Davi.p's Avatar
City & State: Milan
My Country: Italy
must cut one by one tracks with signal name with CK... and see if defect goes..
Old 09-02-2021, 12:44 AM   #10
ioanban
My Country: uk
Attachment 243372
Good morning Davi,
Could you tell me how am I supposed to do that ? a video would be helpful or some description.
Thank you
Old 09-02-2021, 06:54 AM   #11
Davi.p
Davi.p's Avatar
City & State: Milan
My Country: Italy
it's not easy, on the top image i've marked the tracks to be cut, must make cuts of the near track translated not in line, so it's more easy when you join them again, the round pads covered in green have corrispondance with signals labeled in the bottom picture, cut only the ones with CK.., cut until defect goes away , if it doesn't join them all and cut the ones in the other side...
Old 09-02-2021, 03:46 PM   #12
bohaboha
City & State: stockholm
My Country: sweden
Good Evening Davi.p I have read your answer and tried to figure out how to go about implementing your advice but could not. can you please describe a little more in detail how to proceed.thank you
bohaboha is offline   Reply With Quote
Old 09-02-2021, 04:13 PM   #13
Davi.p
Davi.p's Avatar
City & State: Milan
My Country: Italy
Who are you? Not Ioanban?
It's not easy with my english...
In the bottom image you see the silkscreens of the signals that passes in the traces i have marked approximately in the top image, the signals labels refers to the green round pads(testpoints), counting the corrispondant pads you'll cut the traces one by one..
Old 09-02-2021, 04:45 PM   #14
bohaboha
My Country: sweden
hi again Davi.p no I am not Ioanban and my English is worse than yours. I have a samsung tv problem and am trying to find a solution to the one it is posted here : Samsung UE55KU6575U SHOWS ONLY HALF SCREEN if you can help me I will be very happy
Old 09-03-2021, 02:25 AM   #15
Davi.p
Davi.p's Avatar
City & State: Milan
My Country: Italy
Bohsboha it's generally not good to hijack an other one's thread, post your own thread, your defect is different..
Old 09-03-2021, 08:04 AM   #16
ioanban
My Country: uk
Don't worry about your english, it's perfect !
My problem is that i don't know how to physically cut those tracks, i've never done it or seen anyone doing it before.
Thank you for the help Davi
Old 09-03-2021, 08:14 AM   #17
Davi.p
Davi.p's Avatar
City & State: Milan
My Country: Italy
Yes, in the truth i've never done this particular modify and i feel it's very difficult, must use a cutter with very sharp blade and putting it at least 45 degrees or more to the surface and slowly cut paying attention to not to cut adiacent trace.. maybe with help of magnifier..
Old 09-03-2021, 08:18 AM   #18
mmartell
City & State: Windsor ON
My Country: Canada
Easier to try and cover some of the pins on the flex cable with a small piece of tape than to cut a tiny trace. Plus it's reversible by removing the tape.
As per earlier instruction you need to at least narrow which side you should be working in.
mmartell is offline   Reply With Quote
Old 09-03-2021, 10:15 AM   #19
Davi.p
Davi.p's Avatar
City & State: Milan
My Country: Italy
yes i'm very sorry, i made big mistake, tape method should work..
Old 09-05-2021, 02:26 AM   #20
ioanban
My Country: uk
What flex cable are you referring to because it doesn't have a tcom board
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2022
Powered by vBulletin ®
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
