samsung UE49MU6120KXXU image problem
  • ioanban
    • Dec 2020
    • 47
    Hi guys,
    I have a samsung UE49MU6120KXXU with a flickering problem and some lines on the screen.
    I have looked around the forum but i didn't manage to find a solution to my problem.
    I've already tried to clean the cable strips but nothing changed.
    I've atached some pictures with all the boards and a video with the problem for you to get a better idea.
    https://youtube.com/shorts/QNxt4RIdJ0g?feature=share
    Regards,
  • ioanban
    • Dec 2020
    • 47
    Re: samsung UE49MU6120KXXU image problem
    https://www.youtube.com/watch?v=AOnFCJCTACk
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4289
      • Italy - Milan
      defective panel, try disconnecting one flat cable to the screen at a time and watch results..
      • ioanban
        • Dec 2020
        • 47
        I have removed the flat cables one at the time but I'm not getting any image , all screen goes black .
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4289
          • Italy - Milan
          in this case i have no answer for now, must take pictures of the panel's boards searching for silkscreens of signals, if you find some clk-something, must cut them one by one, one side at a time..
          • ioanban
            • Dec 2020
            • 47
            Davi, i have uploaded pictures with all the boards in the first post .
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4289
              • Italy - Milan
              panel's boards are under a metal frame under speakers...
              • ioanban
                • Dec 2020
                • 47
                I have already tried to fiddle with the strips from the panels but i haven't noticed any changes on the screen .
                You have some pictures with the panel boards, i have don them in sections so that you can see them better, attached here .
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4289
                  • Italy - Milan
                  must cut one by one tracks with signal name with CK... and see if defect goes..
                  • ioanban
                    • Dec 2020
                    • 47
                    Good morning Davi,
                    Could you tell me how am I supposed to do that ? a video would be helpful or some description.
                    Thank you
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4289
                      • Italy - Milan
                      it's not easy, on the top image i've marked the tracks to be cut, must make cuts of the near track translated not in line, so it's more easy when you join them again, the round pads covered in green have corrispondance with signals labeled in the bottom picture, cut only the ones with CK.., cut until defect goes away , if it doesn't join them all and cut the ones in the other side...
                      • bohaboha
                        • Nov 2012
                        • 972
                        • sweden
                        Good Evening Davi.p I have read your answer and tried to figure out how to go about implementing your advice but could not. can you please describe a little more in detail how to proceed.thank you
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4289
                          • Italy - Milan
                          Who are you? Not Ioanban?
                          It's not easy with my english...
                          In the bottom image you see the silkscreens of the signals that passes in the traces i have marked approximately in the top image, the signals labels refers to the green round pads(testpoints), counting the corrispondant pads you'll cut the traces one by one..
                          • bohaboha
                            • Nov 2012
                            • 972
                            • sweden
                            hi again Davi.p no I am not Ioanban and my English is worse than yours. I have a samsung tv problem and am trying to find a solution to the one it is posted here : Samsung UE55KU6575U SHOWS ONLY HALF SCREEN if you can help me I will be very happy
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4289
                              • Italy - Milan
                              Bohsboha it's generally not good to hijack an other one's thread, post your own thread, your defect is different..
                              • ioanban
                                • Dec 2020
                                • 47
                                Don't worry about your english, it's perfect !
                                My problem is that i don't know how to physically cut those tracks, i've never done it or seen anyone doing it before.
                                Thank you for the help Davi
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4289
                                  • Italy - Milan
                                  Yes, in the truth i've never done this particular modify and i feel it's very difficult, must use a cutter with very sharp blade and putting it at least 45 degrees or more to the surface and slowly cut paying attention to not to cut adiacent trace.. maybe with help of magnifier..
                                  • mmartell
                                    • Oct 2013
                                    • 3189
                                    Easier to try and cover some of the pins on the flex cable with a small piece of tape than to cut a tiny trace. Plus it's reversible by removing the tape.
                                    As per earlier instruction you need to at least narrow which side you should be working in.
                                    • Davi.p
                                      Hobbist Tech
                                      • Sep 2009
                                      • 4289
                                      • Italy - Milan
                                      yes i'm very sorry, i made big mistake, tape method should work..
                                      • ioanban
                                        • Dec 2020
                                        • 47
                                        What flex cable are you referring to because it doesn't have a tcom board
                                          09-07-2024, 05:50 AM
                                        • howardc64
                                          Samsung UN55JU650DF network/streaming problem
                                          by howardc64
                                          Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                                          This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                                          07-09-2025, 12:44 PM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
