Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Computer Displays
Thread Tools Display Modes
Old 01-07-2022, 11:19 AM   #1
thetonywarren
thetonywarren's Avatar
City & State: Green Bay, Wi.
My Country: USA
Line Voltage: 120VAC 60Hz
I'm a: Knowledge Seeker
Default LG Flatron L1910S DEAD
I have a LG Flatron L1910S that is dead, no led's no backlight nothing.......I took off the back and took a look at the caps, all appear to be good, although I know that's not a true test......I took voltage readings at CW301, Without the main board connected, Im getting 5vdc and 14vdc, WITH the main board connected, Im getting 4.13vdc and 16vdc. Please see pictures for details, I think the attached diagram is correct for the SMPS. Any thoughts or suggestions where to look next....I can send better pictures and take measurements if needed.
Thanks in advance for any help.
File Type: jpg fan7601_lien_chang_ai-0066_l1720p_l1750s_inverter_lcd_sch.pdf_1.jpg (315.7 KB, 10 views)
thetonywarren is offline   Reply With Quote
Old 01-07-2022, 12:56 PM   #2
R_J
City & State: ☻
My Country: Canada
I'm a: Professional Tech
Default Re: LG Flatron L1910S DEAD
I would start by replacing C109 (c108 schem) and C107. See if this fixes the low +5v. It may also be that C205/C206 are weak
R_J is offline   Reply With Quote
Old 01-07-2022, 01:45 PM   #3
thetonywarren
My Country: USA
I changed out C205/C206 with new caps 1000uf/25v, but no change, I guess I'll need to source new caps for C109 and C107, as I dont have those values on hand......
Old 01-07-2022, 03:34 PM   #4
thetonywarren
My Country: USA
Is it possible to subsitute the 0.47uf cap @ C107 with another value? I found a cap to replace C109, but dont have one for C107, not sure if that's a possibility or not?????
Old 01-07-2022, 03:51 PM   #5
thetonywarren
My Country: USA
I have two caps, one of 2.2uf and another is 0.22uf, will either of those be ok???
both are rated at 50v
Old 01-07-2022, 04:57 PM   #6
R_J
City & State: ☻
My Country: Canada
I would suspect C108 first as it is for the vcc of the ic. You could check this voltage with the main connected, but be careful not to short the ic. and this is on the hot side of the power supply. Looks like this vcc should be about +12VDC
I would just bridge the 0.47µf with the 0.22µf and see if it help the 5 volts stay up, Just solder it across making sure the leads don't touch anything else.
Old 01-07-2022, 05:49 PM   #7
thetonywarren
My Country: USA
Before I saw your reply, I soldered in the 2.2uf in place of the 0.47uf just to try it, and it came right on.....I'll get a new 0.47uf and put that in its place when it comes in......I'll update when I get the new 0.47uf cap.......
Old 01-07-2022, 08:36 PM   #8
R_J
City & State: ☻
My Country: Canada
Good to here, I would replace C109 (33µf/50v?) as well, the circuit is on all the time and those small caps dry out over time.
Old 01-07-2022, 09:07 PM   #9
thetonywarren
My Country: USA
Yep, I appreciate the help, I actually replaced every cap on the SMPS, so the bad one was the only one I didn't have on hand.....go figure.......
Old 01-13-2022, 08:51 AM   #10
thetonywarren
My Country: USA
FYI, I replaced the 0.47uf cap and it's working now, I appreciate the help....
Here's a pic of the screen afer cap replacement....
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2022
Powered by vBulletin ®
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
