Change vram on asus rog
    I had to replace the Vram on an asus rog gl502vm gpu gtx 1060 card.
    The original memories is micron D9TCB -> MT51J256M32HF-80 having an identical card that used samsung GDDR5
    K4G41325FE-HC28 so I swapped them.
    The notebook displays but GPUZ returns 0 G and microns as the memory brand ??? (as is possible that appears micron if I changed the memory ?)
    I re-soldered the microns and the notebook works well for a few hours then (probably after some updates) I have a memory conflict that close any game I use but not performance test.
    GPUZ tells me I have 6G of vram while a vram test program tells me I have 3G and it stopped the test . The firmware of the video card has been replaced, with a hex editor I know it is for the right model of rog but I cannot find information on the supported giga or the supported brand memories (how do you get this information from a graphic bios?) now I'm a little confused about the density of these chips:
    1 D9TCB -> MT51J256M32HF-80 = 1G each chip ??
    2 K4G41325FE-HC28 = 1G each chip ??
    I would like to know for sure the amount of memory installed as the GPU firmware may be wrong
    Re: Change vram on asus rog
    K4G41325FE-HC28 is 512MB chip so you got 3GB of VRAM. 3GB and 6GB gtx 1060 had different GPU die, they are not fully compatible as far as I know.
      Both chip on the two boards (one with 3G second with 6G) have the same id number but the firmware is not the same for 3G or 6G Vram .
      Unfortunately for the gtx 1060 there isn't a tool to investigate about the firmware so the only way is to try different dump and see what's happen. At last I change the vram with sansung
      K4g80325fb-hc25 desoldered from another rog board with same gpu and 6g
