XVDV55 Pioneer , no disc play
  • zen
    • 511
    Hi all
    Seems that the CD reader had failed .
    Could only find it listed on Ebay via Liberty Electronics .
    Have bought from them before & been quite reliable .
    Quite an expensive part & wondering if there are any other suppliers in UK , or Europe so that i can save on post .
    https://www.ebay.co.uk/itm/282281869568
  • zen
    • 511
    Re: XVDV55 Pioneer , no disc play
    CD reader arrived , but thought before i fit ,will check caps on the servo board .
    Replaced several with poor readings .
    Now for the reader .
    • zen
      • 511
      Reader fitted & on test with a music CD
      • zen
        • 511
        A few other issues with this unit .
        On occasion when tray ejected , it would retracted by itself .
        Pulled tray out to access the detect switch , & cleaned with IPA
        Also the FRONT speaker audio would cut out intermittently .
        Discovered the top 2 speaker protect relays corresponding to FRONT were dry jointed at the coil side .
        • zen
          • 511
          Remote control not working either .
          Once stripped down issue was self evident .
          Glue once used to secure the 8MHZ oscillator had become corrosive .
          A replacement restored operation .
          • zen
            • 511
            Play back was still a touch temperamental .
            To resolve this removed turntable motor & sprayed some IPA through the underside onto brushes .
            • zen
              • 511
              Yet again from a cold start , after being off for a day , it wouldn't play .
              Took a hair drier to the PSU module , then sprang into life again .
              Time for more cap replacements i think .
              • zen
                • 511
                One cap found with a very poor ESR reading , C5012 ( 10MF , 50V )
                Hopefully this is the cause .
                • zen
                  • 511
                  Powered , tested from cold start on two consecutive mornings & all good so far .
                  • Junior††
                    PS5 Disc Not Supported/ Disc Not Recognized Board Num: EDM-020
                    by Junior††
                    Good Afternoon fellas,
                    Issue:
                    Disc is showing as not supported when a disc is put in.
                    Here's what I've done, you can skip this if you just wanna know the question:
                    - replaced with a disc drive from a donor ps5 (honestly questionable if this is known to work)
                    - reflowed the disc drive connector
                    -reflowed the chip in question (shown on image)
                    - I will say this console was very dusty so it's conceivable that it got so hot that it made the chip joints cold and potentially other things on the board
                    Question:
                    I...
                    02-19-2025, 12:48 PM
                  • pixelcap
                    Pioneer Kuro Pro 111FD 8 red blink error
                    by pixelcap
                    Pioneer Kuro Pro 111FD 8 blink red LED.
                    I have been trying to solve the power-down 8-blink red LED problem with my Pioneer.
                    So far I have replaced the power supply board, and the digital assembly board, I have reconnected the ribbons to all boards, ensuring the connections are good. Even though the problem is the 8 red light error and not the more common 8 blue light error code, I had Kcrownie,
                    based in North Carolina replace the chips that cause the 8 blue LED problem (the main board and audio board) the plasma is still powering...
                    10-06-2024, 11:26 PM
                  • Evets
                    Pioneer sg530
                    by Evets
                    This forum has been so useful to me and I thank all the people who have helped me in the past.
                    I'm now in need of some more assistance, I have purchased a Pioneer sg530 graphic equaliser to add to my Pioneer X-G7 hifi system. This equaliser was a factory option on this system but as this was purchased second hand I didn't get a user manual. Searching the internet has been fruitless, can anyone help with a schematic of how this should be wired into the system or possible a copy of the user manual.
                    07-30-2024, 07:18 AM
                  • Dobsuk
                    CD Player Pioneer PD-Z560T does not open trays
                    by Dobsuk
                    Hi, i have got one Pioneer PD-Z560T 2 CDs player. The problem is that it is open tray 2 but close it immdetiatelly and does not open tray 1 at all. At the same time it does not play the CD which i managed to insert into tray 2. Just uploaded some short videot here as it is not very easy to explain that is happening. I can hear some noice as something is trying to spin the disc or something but do not have any idea when it is coming from.
                    Any advises, please? Thanks.
                    08-21-2022, 09:41 AM
                  • m4a2t0t
                    Disc caps
                    by m4a2t0t
                    Can I replace a ceramic disc cap with a multilayer ceramic cap? I cant even find .047 uf disc caps at digikey, mouser or newark. The places I do find them want anywhere from 25c to $3 each, at any quantity, plus shipping....
                    01-18-2024, 10:00 PM
