#141 |
City & State: Porto
My Country: Portugal
I'm a: Hobbyist Tech
![]() e)
Changing supply voltage from 5V to 3.3V will degrade performance and accuracy for both MCP3421 (INL vs. Supply Voltage) and AD8628 (Signal Voltage Gain). f) Even for DIY project it's taking too long to see the daylight! IMHO it's well time to move the hands from keyboard to a bread board or a prototype board... |
#142 | |
City & State: San Antonio
My Country: United States
Line Voltage: 120v 60hz / 240v 60hz
I'm a: Hardcore Geek
![]() Quote:
I'm asking because it would be really nice to sub out a pi pico for the nano. Nanos had their time, and that time is passing. Unfortunately, it's a 3v3 board (can take power from 1.8 to 5.5v) and the pins aren't 5v tolerant. I have an pi pico in the mail, should be here on mondy, I'm going to see if I can get the software running on it. Would make an interesting option, and not very expensive at 6 usd. https://ww1.microchip.com/downloads/...ets/22003e.pdf https://www.analog.com/media/en/tech...-8629-8630.pdf |
#143 |
City & State: Europe
![]() the original design was 3.3v - so i presumed it could work.
and the oled runs at 3.3v no issues |
#144 |
City & State: Alberta
My Country: Canada
![]() I think the original circuit does not push much current through the probes?
BC557 switching around 56mA but most of that goes through R2 2Ω which is in parallel with the tested resistance, and by current-division gives around 1.4mA only to the probes. Test voltage aound 113mV which is good. If this is right, then the source needs an update to pass more current through the resistor under test. Not a new vreg. |
#145 | ||
![]() Quote:
I'm not really sure of the severity of the issue he was trying to hunt down, the videos sure look like he has a functional device. Could be an issue of the perfect being the enemy of the good. I'm pretty sure I'd be fine with an 80% solution when what I have right now is a 0% solution. ![]() I took a look at the code, he bit bangs the registers, so I'm going to have to get the datasheet out, but should be able to figure out what he's doing and get it going on rp2040. Last edited by clearchris; 07-02-2022 at 02:42 PM.. |
#146 |
My Country: Canada
![]() I'm wrong about some of the test currents. I checked math again and the circuit with 5V is putting a max of around 58mA through the resistor under test, with 114mV open-circuit. So this looks quite reasonable, assuming the (Arduino Nano V3) and 9V battery power supply holds up.
With a test resistor of 1Ω that's 38.6mV and 38.6mA With a test resistor of 0.1Ω that's 5.6mV and 55.6mA With a test resistor of 1mΩ that's 58.4uV and 58.4mA The op-amp is a bit noisy then, after it is 1.578mV to the ADC input, a little small. I don't see any deal breakers, other than 5V '328 with 3.3V OLED and no cap across R8 and R7 for filtering incoming noise, you could try average it out in firmware. In the mΩ measuring it's in the noise floor and battery limit. You guys want 1A?! Any inductance and that would wallop what you are testing... |
#147 | |
City & State: Porto
![]() Quote:
Off course we're talking about peanuts... but when it comes to detecting µΩ ![]() |
#148 |
City & State: Porto
#149 | |
![]() Quote:
Megaraider: Yeah, you got me, good catch. There's definitely value in feeding the AD8628 5v. There's likely also a lot of value in adding a constant current source the the probes. Reading the code, krypton uses a gain of 1 for the MCP3421. Not sure if there's any value in changing the gain on the ADC, if we want more gain, we should probably change the amplifier to get a bit more range. Upping the gain on the MCP3421 adds a bit of noise, though I'm not sure how much a difference of 5uV matters. For this application dealing with uOhms, maybe a lot. If we are dealing with 1.578mV to the ADC input we could run the ADC on 3v3 (to get 3v3 communication to the MCU) and it should be fine. Everything else can run 5v including the OLED. I'm just throwing out some ideas, I'm not necessarily advocating (ok, maybe for the rp2040, but I'm not married to it) you guys know this stuff far better than I do. I suspect krypton was putting some effort into keeping the BOM down, but I wouldn't have any issues bumping it up (suggestions so far, not all by me, amp, mcu, transistor, constant current source, more caps) if it increases quality. BTW, I noticed that the VoutAOP line to the MCU in the schematic isn't used in the code. Is there any reason you would need this line? It's probably just a source of noise if it isn't used. |
#150 |
![]() someone on eevblog came up with this mod
#151 |
City & State: Some times Sunny Jacksonville FL
Line Voltage: 120 Volts 60 HZ
![]() Is the person who started this post going to make a kit available for purchase just asking the question
9 PC LCD Monitor 6 LCD Flat Screen TV 30 Desk Top Switching Power Supply 10 Battery Charger Switching Power Supply for Power Tool 6 18v Lithium Battery Power Boards for Tool Battery Packs 1 XBox 360 Switching Power Supply and M Board 25 Servo Drives 220/460 3 Phase 6 De-soldering Station Switching Power Supply 1 Power Supply 1 Dell Mother Board 15 Computer Power Supply 1 HP Printer Supply & Control Board * lighting finished it * These two repairs where found with a ESR meter...> Temp at 50*F then at 90*F the ESR reading more than 10% 1 Over Head Crane Current Sensing Board ( VFD Failure Five Years Later ) 2 Hem Saw Computer Stack Board All of these had ![]() All of the mosfet that are taken out by bad caps ![]() |
#152 |
#153 |
#154 | |||||||||||||||||||
![]() I went through the Badcaps and EEVBlog thread and pulled out the relevant posts before our most recent discussion. Here it is for reference:
## Link to Krypton's Shorty Page http://kripton2035.free.fr/Projects/shorty-display.html ## EEVBLOG POSTS OF INTEREST Quote:
https://www.eevblog.com/forum/testge...28/#msg3461128 Quote:
https://www.eevblog.com/forum/testge...98/#msg3515698 zoltahn: Quote:
https://www.eevblog.com/forum/testge...70/#msg3516070 nikifena: Quote:
nikifena: Quote:
Nikifena: Quote:
https://www.eevblog.com/forum/testge...28/#msg3541928 nikifena: Quote:
https://www.eevblog.com/forum/testge...20/#msg3544020 kripton: Quote:
kripton: Quote:
kripton: Quote:
https://www.eevblog.com/forum/testge...56/#msg3578156 BADCAPS POSTS OF INTEREST: Quote:
https://www.badcaps.net/forum/showpo...07&postcount=5 ###clearchris note: pic of probe tip connection, twisted two wires to probe? https://www.badcaps.net/forum/showpo...1&postcount=12 Quote:
https://www.badcaps.net/forum/showpo...8&postcount=44 Quote:
https://www.badcaps.net/forum/showpo...4&postcount=87 Quote:
https://www.badcaps.net/forum/showpo...6&postcount=88 |
#155 |
![]() Ok, I was able to get the software compiled and on a Pi Pico (rp2040). There were some register bit banging, I didn't translate that yet, but I don't see why that wouldn't work.
Again, I'm offering this as an option, I don't have PCB skills, so I'm not driving the bus should anyone decide to make a PCB. |
Thread Tools | |
Display Modes | |
