Lenovo 300e Chromebook
  • comipok
    • May 2020
    • 9
    • ua
    Hello everybody.
    Help unlock the Lenovo 300e Chromebook. There is an administrator lock
  • RethoricalCheese
    • Mar 2013
    • 1517
    • Estonia
    Re: Unlock the Lenovo 300e Chromebook
    A picture is useless. Upload bios dump.
    • comipok
      • May 2020
      • 9
      • ua
      bios orig
      • vinsun0399
        • Aug 2019
        • 38
        • Jakulin
        google password
        • RethoricalCheese
          • Mar 2013
          • 1517
          • Estonia
          Use this dump. Turn on laptop, boot to recovery mode (esc, refresh and power, hold esc + refresh until in recovery mode). Press ctrl + D, press enter. Press ctrl + D and press enter again. Don't remember the exact process but the idea is to try gp tp developer mode. It usually says that dev mode is disabled but that does not matter yet. Anyway, you just need to wait until laptop restarts. It should clear all data. Then just let it boot normally and log in with your gmail account. Then go to settings and powerwash. After you powerwash, dev mode should be unlocked and you should be able to use any gmail account.
          • comipok
            • May 2020
            • 9
            • ua
            Use this dump.
            Thank you, but when performing this function, it displays information to me - "developer mode is off"
            • RethoricalCheese
              • Mar 2013
              • 1517
              • Estonia
              Yes, let it restart, then log in and power wash.
              • comipok
                • May 2020
                • 9
                • ua
                After resetting, the Internet connection is required. When connected, activates the old profile
                • m3mo3y
                  • 31
                  • Sweden
                  [Chromebook] lenovo 300e bios chip model??
                  hello there i have a lenovo 300e chromebook that i lost the bios chip for..
                  i have the dump and i know its a 1.8v chip but i lost the chip while attempting to dump it ..
                  so please it anyone know what is the model of it hat would be dope
                  thanks
                  • lapfix
                    • Mar 2020
                    • 2635
                    • my workshop
                    Re: [Chromebook] lenovo 300e bios chip model??
                    thanks
                    If you still have the dump post it
                    • m3mo3y
                      • 31
                      • Sweden
                      sure bro
                      • imranromi
                        • Jan 2015
                        • 1288
                        • Pakistan
                        thanks
                        You can use bios chip Winbond 25Q64FW. Fw is 1.8v bios chip.
                        • m3mo3y
                          • 31
                          • Sweden
                          thanks bro i tried this chip and it worked but the problem is that i cant activate the device cant login !! so im assuming that the chip is not working
                          and 25Q64FW is a 64mb chip and my dump is 4mb !!
                          • 5chematic
                            • Jun 2019
                            • 77
                            I haven't work with chrome laptops that much. but I have unlocked a few in the past. it is very rare to receive a chrome laptop with a bios password. the problem I've seemed with chorme laptops is admin password, which have nothing to do with the bios but with the google account. in my case I have taking them apart and remove a screw to gain admin control. so the chip .bin that was shared here is not going to solve this issue. as for the activation, the .bin file is not going to help either.
                            • tinto
                              • Jul 2017
                              • 74
                              • serbia
                              Lenovo 300e ChromeBook 2nd Gen BIOS LOCKED
                              can anyone help
                              Lenovo 300e ChromeBook 2nd Gen , Bios is locked
                              this is my original bios dump 16mb, chip Type W25Q128BV
                              • RethoricalCheese
                                • Mar 2013
                                • 1517
                                • Estonia
                                Re: Lenovo 300e ChromeBook 2nd Gen BIOS LOCKED
                                Flash this, try to switch to devmode (you probably cant but that doesnt matter). Let it restart normally after that. You should be able to log in now. After logging in, do powerwash. After powerwash, it should be unenrolled and with dev mode unlocked.
                                • tinto
                                  • Jul 2017
                                  • 74
                                  • serbia
                                  RethoricalCheese
                                  Yessss your dump is OK
                                  butttttt I tried 45min of your instruction...and every time when i try to LOG IN ,I have to connect it to the internet...after that, it locks again !!!
                                  in the end I tried last chance:
                                  on another chromebook i made a bootable usb with new chromeOS for this model(on motherboard is 300e/500e 2nd Gen)
                                  i installed new chromeOS on Lenovo e300 and after Power On , i try POWER WASH (ctrl+alt+shift) and I succeeded
                                  after the restart, I logged in normally, everything works ok
                                  Thanks RethoricalCheese
                                  this is the solution for the Lenovo e300
                                  • RethoricalCheese
                                    • Mar 2013
                                    • 1517
                                    • Estonia
                                    Trying to go to devmode is important in this method. Maybe you did something different there that it didn't work straight away, not sure.
                                    • tinto
                                      • Jul 2017
                                      • 74
                                      • serbia
                                      after all, You must install new chromeOS,and then POWER WASH
                                      • RethoricalCheese
                                        • Mar 2013
                                        • 1517
                                        • Estonia
                                        Well, I did come up with this solution and it has worked on hundreds of different chromebooks, including lenovo 300e. I have never had to install new chromeOS for it to work. But since it works for you and you are happy with it then its all OK.
                                          Lenovo 300e Chromebook Specification for Upgrade or Repair
                                          This specification for the Lenovo 300e Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 300e boardview and 300e schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo 300e Chromebook...
                                          09-06-2024, 02:34 PM
                                          09-06-2024, 02:30 PM
                                          09-06-2024, 01:21 PM
