Purpose of this covering on a Dell laptop system board?
  • cook
    Quiet observer
    • May 2010
    • 100
    The Dell laptop pictured in this post has an area of the board covered with a dull silver material. It is the large 'square' area on the lower right that sits right next to the two card slots. When I removed it from my board, it felt like it was thick paper that has glue on one side, and the other side has a silvery material on it that crumbles off very easily. As it crumbles off it leaves a silvery color on your skin. Underneath of this cover, there are many chips, and there are two big chips from SMSC, which I assume are for the card slots. Other parts of the board are covered with a sheet of thin clear plastic, though this is not shown in the picture. In summary, Dell is using two very different coverings at places on the board.
    My questions are only about the silver covering shown in the picture. ..
    Why did they put this on the board? (Heatsink? Physical protection of the board?)
    Is it OK to use the board without this on it?
    Thank you.
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • m1ch43lzm
    by m1ch43lzm
    05-12-2025, 08:37 PM
  • Garret Matt.
    DELL Latitude 5430 Rugged CORE_D5K Rev.A00 Schematic and/or Board View
    by Garret Matt.
    I'm Working on replacing an Inductor on this Dell's board and I need to come up with a compatible replacement. As much as I would like to smash a comparable 2R2 in the same spot I'd like to confirm the specs before confirming a killed board. For my purposes I'd be happy with a second opinion on the replacement inductor or the actual schematics/board view. As this is a commonly used Dell Rugged in my local service area, schematics would greatly help in the future.
    Thank you in advance for any assistance you can render.
    Inductor In question. Buzzes like...
    06-20-2025, 01:21 PM
  • Bowline
    by Bowline
    06-11-2025, 10:13 AM
  • guy960915
    need help labeling Dell P2210f board diagram
    by guy960915
    Hello guys, i need help labeling Dell P2210f Monitor board diagram , can't find any online.
    i am replacing it with LED Backlight.
    thank you.
    10-22-2024, 11:51 AM
