FLUKE 43B PM8907 power supply repair
    Have two dead out of four power supply for (4) FLUKE 43B.
    The resistance reading on the two power prongs shows open circuit.
    Open up the module, you will need security bit, and found hair line crack on the circuit board. Too bad that FLUKE did not spec in fiberglass PCB to build this power supply.
    Fixed the broken traces and added epoxy to the PCB to help supporting the board.
  • mmartell
    • Oct 2013
    • 3189
    Re: FLUKE 43B PM8907 power supply repair
    Good eye, bud.
    • mockingbird
      • Dec 2008
      • 5484
      Hope you swapped out that "Stone" brand cap. They have all the longevity of a croissant at a feminist buffet.
        Power supply is made in Germany with lousy cap. The replacement power supply is around $100.
          Very disappointing for Fluke. Then again, after seeing CapXon in a Tektronix signal generator, I'm not too surprised.
          My Rigol scope uses Epcos caps, even though it is made and designed in China, they are OK caps. Not the best, but far from the worst...
          • mockingbird
            • Dec 2008
            • 5484
            Epcos is not a reliable brand. I've seen Dave Jones claim they are, but he's wrong.
              EPCOS are one of the largest manufacturers of capacitors primarily used in industrial and hi rel applications where the Japanese brands don't fill the market and they also cost a little less. For example they're a lot better at higher temperatures - the water electrolyte in the Japanese caps can boil off at high temperatures, reducing reliability.
              I have reasonable confidence in them. I doubt they're as good as a Rubycon or Panasonic, but I wouldn't call them unreliable. I've never seen one go bad.
              • ben7
                Capaholic
                • Jan 2011
                • 4059
                Like tom, I've never even heard of them going bad? Have you?!
                Muh-soggy-knee
                • retiredcaps
                  • Apr 2010
                  • 9271
                  Thanks for sharing. I'm surprised they are made in Germany and not China.
                  --- begin sig file ---
                  --- end sig file ---
                    by sam_sam_sam
                    03-31-2024, 02:12 PM
                    by sam_sam_sam
                    07-01-2024, 06:34 AM
                  • JimBanville
                    Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                    by JimBanville
                    The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                    Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                    I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                    I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                    09-13-2023, 07:21 AM
                  • CMCM
                    Russound CA4 Power Supply Repair
                    by CMCM
                    Hello Everybody,
                    Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
                    Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
                    The outputs marked 12v and 20v are all measuring only 1v.
                    The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
                    The capacitors physically look clean (no bludgesor leaks) and...
                    07-03-2025, 01:12 PM
