Is This an Isolation Transformer ?
  • mmartell
    • Oct 2013
    • 3189
    Patronics CA1000JH. Two outlets, a switch, a fuse and a large transformer. That's it. Bought it for $8 at a resale shop.
    Re: Is This an Isolation Transformer ?
    No, the bad part is that, they put the AC power input fuse on the Neutral (White wire) instead of the Hot wire. You should verify that Hot and Neutral wires are properly wired up.
    • mmartell
      • Oct 2013
      • 3189
      How do I verify that ? I plugged a lamp into it at the store and the lamp came on.
      If it's not an Isolation Transformer then what is it ?
      • goontron
        5000!
        • Dec 2011
        • 4108
        • US
        its a buck/boost transformer. 220v for australian junk and 100v for old radios.
        (thats what i use mine for at least)
        Follow the white rabbit.
          It is an multi-tap autotransformer. You can use you AC voltmeter and the measure the AC voltage between the Neutral and Ground, Hot and Ground to see what you get. In US, the Neutral is tied to ground at the circuit breaker panel, so Neutral to Ground should show 0V (it may show perfect 0V if there is load in the same circuit using that same Neutral wire.
          • mmartell
            • Oct 2013
            • 3189
            Hmmm... so "junk" is what you're telling me...
            • goontron
              5000!
              • Dec 2011
              • 4108
              • US
              if you dont want it i will take it! my fried years ago.
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8679
                Yep autotransformer. There is no isolation - you can see that one wire of the input (120V) is connected to both outputs - that's not isolation.
                It's how to get 220V for European devices in the USA. I was wondering about Patronics, is that a Canadian company? They don't seem to be well listed on Google.
                I have only a Sabir 250VA autotransformer to get 220V from 120V or 120V from 220V. This one is also an autotransformer (no isolation) and was made in France as far as I can tell... Unfortunately it definitely was made in the EU as the input plug is a dual pin and thus can't really use it without an adaptor or modification...
                • domas
                  News Hater
                  • May 2013
                  • 323
                  • Denmark
                  not only australian there is another moderately large continent across the pond that is using 220v
                  • harp
                    isolation transformer from two 240/12, wiring?
                    by harp
                    When is talk about making isolation transformer on poor-man way, always I see schematic 240/12-12/240.
                    So, I wonder, is this wiring from my attachment it work, bringing some good feature or it is bad idea and why?...
                    11-25-2022, 05:11 PM
                  • ohren
                    Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                    by ohren
                    Hello!
                    I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                    Measured voltages with no load:
                    After rectifier diodes
                    12V: 6.17 V
                    5V: 5.67 V
                    Secondary transformer pins AC measurement (really don't know if this says anything)
                    12V: 2-2.5 V
                    5V: 1.04 V
                    I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                    03-18-2023, 10:33 AM
                  • mikey5791
                    Is it possible for transformer substitution?
                    by mikey5791
                    Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                    Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                    My questions are
                    1. How do i test to see if the transformer is in good working condition?
                    2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                    Hope you guys understand what i was asking. My intention is...
                    11-03-2022, 02:11 AM
                  • dennis_elx33
                    3PHASE STEP-DOWN Transformer in Check
                    by dennis_elx33
                    Hello All,
                    i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
                    Problem statement: Power tripped Off
                    Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
                    Action Done:
                    1) Replaced the faulty parts with good spare.
                    2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
                    12-02-2024, 06:52 AM
                    ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) Book Specification for Upgrade or Repair
                    This specification for the ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T101HA - X5DHD boardview and T101HA - X5DHD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                    09-06-2024, 04:40 PM
