Hakko 936 wattage enough?
  • bord
    • Feb 2014
    • 19
    • South East Asia
    The older Hakko 936 actually uses a 50W heater element (888 is 65W) and I was wondering if the lower wattage will present a problem for desoldering/soldering the bigger connections on current motherboards.
    Heater element wire type instead of a fuse when troubleshooting a short circuit DIY
    by sam_sam_sam
    I was Ollie today which is a close out / surplus outlet store I do not go in there to often because you find things that you should not be tempted by but that is a another story
    I saw a small space heater that used a wire type of heater element which I been looking for a while but not really hard mind you but when I saw this I grabbed it I going to go back tomorrow and buy the last one that is like the one I bought today because I need the heater element and the ceramic insulators and more of heat element wire because this one has two different wattage settings one 1300 watts ( tap...
    12-16-2023, 08:39 PM
  • edugimeno
    Vaillant 242 Gas Water heater. Shortcut in board anc compatibility with model 282
    by edugimeno
    Hi!!
    Yesterday I was installing a new Wifi thermostat for my domestic gas water heater model Vaillant 242/2-3, and accidentlly one wire from mains touched one wire from the thermostat output contacts. This shut off the heater so I finished installing the thermostat and then went out to check the heater
    I found one fuse blown (T2 250V). Replaced it with another equivalent fuse and it blew right away. I measured L-N in mains input and I sometimes got 4K but sometimes, not sure why, I got 100 Ohm...
    At a certain point, moving stuff around, I put all wires back in place and...
    03-24-2024, 02:31 PM
  • madan1
    Diesel heater emergency power supply / poor man's UPS
    by madan1
    Hello everyone.
    Some background - I have one of those chinese diesel heaters, which I'm using to heat a garage. Probably most of you are familiar with that units, but here is some basic info - the main heater body is enclosed with the motherboard+sensors unit inside a plastic case. The heater has a glow plug, that works only when the unit is starting (start the fire in the burner) and stopping (make sure to completely burn the fuel inside the burner) and two fans on a single motor. One fan is used to push fresh air in the burner, the other is used to push cold air in the case and...
    12-18-2022, 08:05 PM
  • flysky
    Gigabyte H610M S2H V2 help to identify the element.
    by flysky
    There is a motherboard Gigabyte H610M S2H V2 (DDR5), I can't find boardview
    Help to identify the element, marking on the element - C31PH. It stands next to the USB 3.0 and it looks like it is ESD Protect chip. We need a datasheet to this element. Maybe someone has already identified such an element. Help please.​
    01-23-2025, 07:21 PM
  • EasyGoing1
    The best way to drive a heating element?
    by EasyGoing1
    I've got this circuit that I've been playing with on a breadboard. I'm not happy with it mainly because the MOSFET gets too hot and generally controlling the temp of the heating element with the Arduino has proven to be a little more cumbersome than I would like.
    What I would like to know, is what is the best way to set up a circuit like this? The heating element is just a PCB and its going to be mounted under a 3D-printed enclosure that a lizard will use to warm his belly.
    This is the general setup that I have now.
    This is what the...
    01-25-2023, 11:29 AM
