How do you correctly use a Lab Power Supply?
    by sam_sam_sam
    03-31-2024, 02:12 PM
    by sam_sam_sam
    07-01-2024, 06:34 AM
  • JimBanville
    Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
    by JimBanville
    The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
    Opened it up and discovered the power supply is making a faint clicking or ticking sound.
    I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
    I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
    09-13-2023, 07:21 AM
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • CMCM
    Russound CA4 Power Supply Repair
    by CMCM
    Hello Everybody,
    Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
    Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
    The outputs marked 12v and 20v are all measuring only 1v.
    The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
    The capacitors physically look clean (no bludgesor leaks) and...
    07-03-2025, 01:12 PM
