Emergency question!
On this PSU Board for a Monitor, Between R403 and ZD406 there is a capacitor leg.
I used Red and Blue pen in the picture to point at what I believe is traces connecting these three parts together.
If I pulled a pad off removing that capacitor can I just solder that one leg of that capacitor directly to the leg of R403 and ZD406 or use one of those circuit pens to reestablish a connection or is my PSU finished?
This really sucks. I believe I pulled the pad right through the hole with the capacitor wire.
Does the leg closest to the outer edge of the PCB between R403 and ZD406 connect both R403 and ZD406 or does it only connect to R403?
Am I correct in thinking I can repair this or is this a done deal?
I was close to half done removing capacitors when this happened.
I included a picture so you can see what I am talking about.
