a safety warning!
    a safety warning!
    so the other day i got given a Hot-air rework unit.
    while checking it i found a design error.
    the result was it was not earthed!
    it has a 3pin inlet, a metal case and a metal ended head that uses a mains powered heater in it.
    the problem was simple, the earth's are all connected by a screw in the base of the case,
    but it was insulated by the powder coating.
    so you need to remove the screw and sand/grind some of the coating away inside where the terminals go.
    then reasemble & check it.
    so if you have a unit that looks even remotely like these you should check it with a meter between the case and inlet.
    Re: a safety warning!
      Also check (if you are in the US) that the fuse is on the Line side, not on Neutral wire.
        that would be down to the power cable,
        the fuse holder is integrated into the socket & the socket is an IEC polarised type.
          Most of the Tenma products for US has captive power cord, most Euro version have IEC inlet for so they can use difference kind of power plug. It is always best to inspect the units real well first.
            How does the station itself perform? Would you recommend it to others?
              it's o.k. for the price.
              about $80 without temperature display.
              but if i was paying for one, i'd go for one with digital temp display and airflow display.
              to be blunt, the actual business end and the pump dont change much from model to model - just the features of the controller
                I've generally found them to be OK but the heating elements rarely last beyond about a year so be prepared to buy a new one. The elements are about £10 each from eBay.
                  i'v seen them for half that.
